Galilean transformation / calculating frequency problem
The discussion focuses on calculating the frequency of oscillation for a mass on a moving cart with constant acceleration, given a potential of V=A4x^4. The user is uncertain about how to apply Galilean transformations and Taylor series to derive the equation of motion necessary for frequency calculation. They are particularly confused about whether to transform the variable x in the potential equation and how to properly apply the Taylor series expansion. The transformation they attempted is x' = x + (1/2)at^2, but they seek clarification on its correctness and implications for the potential's dependence on time. Assistance is requested to navigate these concepts and solve the problem effectively.
Lindsayyyy
Hi everyone,
I have a mass like in the drawing and a moving cart with constant acceleration. The potential (also in the drawing) is given as V=A4x^{4}
I want to calculate the frequency of the oscillation of the mass as a function of the acceleration when the cart is moving.
Taylor series(?)
differential equation
F=-grad V (here F=-dV/dx)
Well, I'm stuck. I have a moving frame of referenca and a stagnant one. My problem is I have to find a equation of motion in order to find the frequency. I think I need to develop a harmonic potential via Taylor series. But I'm so unsure when it comes to transformations as I'm new into this. I don't know if I even have to transform the x in the potential equation or not and around which point I should make the Taylor series etc etc.
My attempt was to use the transformation:
x'=x+ \frac 1 2 a t^{2}
Is this even right? Do I have to put the x' in the equation for the potential? Then the potential depends on time aswell? Can someone help me out with this problem and give me any hints?
Thanks for your help
sorry, I forgot the drawing
  • · Replies 42 ·
