Gaussian Radius of curvature in an argon ion laser
lauraboyleify
Hi, having a bit of trouble with this question
"In an argon ion laser ( λ = 514nm) the minimum beam waist is 1.0mm and is close to the plane mirror. Calculate the radius of curvature of the beam at the output mirror. 1.15m away"
Attempt at a solution:
θ = 2λ/pi W02
R = Z + ZR2/Z
ZR = piW02 / λ
I used
W0 = min beam waist = 1.00 mm
Z= distance from beam waist to mirror = 1.15m
And found Zr with the formula and used it in the Radius of curvature, R formula but got the worng answer. I got R = 33.5m
The answer given is R = 3.08m
Beam width isn't beam radius!
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
