Does Distance Affect the Electric Field Strength Above a Charged Plate?
The discussion centers on the effect of distance on the electric field strength above a charged plate. It is established that for an infinite sheet of charge, the electric field remains constant regardless of distance, as indicated by the principle that E-field lines are perpendicular to the plate. The confusion arises from the application of the point charge formula E = kq/r, which is not applicable in this scenario. For finite sheets of charge, distance does matter, but only when the observer is far enough away from the sheet.
  • Understanding of electric fields and their properties
  • Familiarity with Gauss's Law
  • Knowledge of point charge versus infinite sheet charge configurations
  • Basic mathematical skills for manipulating equations like E = kq/r
  • Study Gauss's Law and its applications to electric fields
  • Learn about the differences between electric fields from point charges and infinite sheets of charge
  • Explore the concept of electric field lines and their significance
  • Investigate the behavior of electric fields from finite sheets of charge at various distances
Students of physics, electrical engineers, and anyone interested in understanding the principles of electric fields and their behavior in relation to charged plates.
oh.rry21
So I'm trying to understand a couple things regarding this.
lets say we have a plate that's charged to Q. and we want to find the E field of a point .1 meters above the plate. when i looked at the solution, it never took the .1 meters into account when calculating the strength of the E field.
my roommate says that E field should be the same and thus the distance was irrelevant. so whether it was .1 meters or 1 meter above the plate, the E field would be the same.
but that doesn't make sense to me when you think about the equation for an electric field E= kq/r.
can anyone resolve that contradiction for me? :(
He's right, at least if you're talking about the field from an infinite sheet of charge. Or a finite sheet of charge at distances much smaller than the dimensions of the sheet. Of course, if the sheet of charge is only 10 cm square, the field 10 m away certainly will depend on distance.
That's the field from a point charge--a very different configuration from an infinite sheet of charge. (Of course, as you get far enough away from a finite sheet of charge the field begins to look more and more like the field from a point charge.)
You might want to browse through this site: http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/gaulaw.html#c4"
Yep, because the e-field lines will be 100% perpendicular to the charged (supposedly infinitely wide) plate.
i.e. going straight up or straight down, so if you bound a gaussian cylinder above and through the plate, the field will go through only the circular discs at the end of the cylinder (and not the 'side walls' of the cylinder) - so it doesn't matter how high the cylinder is (drawing a picture would help heaps)
  • · Replies 26 ·
  • · Replies 16 ·
