jojosg
- Messages
- 51
- Reaction score
- 6
- Homework Statement
- The following figure shows a geared transmission system, in order to minimize the axial force on shaft II, please (1) determine the hand of helical gears; (2) determine the revolution direction of worm gear and its hand; (3) draw the three force components on helical gear 2, bevel gear 4 and worm gear 6.
- Relevant Equations
- For helical gears:
Axial force direction rule: Right-hand rule for right-hand helix, left-hand rule for left-hand helix.
To minimize total axial force on a shaft: the axial thrust from helical gear 2 must oppose the axial thrust from bevel gear 4.
Bevel gear axial force always points **toward the large end of the bevel gear**.
Worm drive: Worm axial force = worm gear tangential force; worm tangential force = worm gear axial force. Handedness and rotation direction follow the right/left-hand screw rule.
- Helical gear hand selection:Motor rotates gear 1 downward on its right side as drawn.Bevel gear 4 on shaft II has its axial force pointing to the left (toward the cone apex / large end).To cancel this axial force, helical gear 2’s axial force must point to the right.If gear 2 axial force points right, gear 2 is right-hand, and mating gear 1 is left-hand.
- Worm (gear 5) hand and rotation direction:Bevel gear 4 drives bevel gear 5, so shaft III rotates downward when viewed from the top.We want worm 5 axial force to be consistent, and the worm must be right-hand.Worm rotation direction: counterclockwise when viewed from the top of shaft III.
- Force components summary (this is where I am unsure):
- Helical gear 2: [itex]F_t[/itex] tangent opposite rotation, [itex]F_r[/itex] radially inward, [itex]F_a[/itex] to the right (to oppose bevel gear axial force).
- Bevel gear 4: [itex]F_t[/itex] tangent, [itex]F_r[/itex] radially inward, [itex]F_a[/itex] toward the large end (to the left).
- Worm gear 6: [itex]F_t[/itex] tangent, [itex]F_r[/itex] radially inward, [itex]F_a[/itex] opposite to the worm tangential force.
