Undergrad Understanding Gravity with GR: Beginner's Guide by Aerodyn
This discussion focuses on the fundamental concepts of General Relativity (GR) and the nature of gravity as an inertial effect rather than a force. Participants clarify that an accelerometer on the Earth's surface reads 9.8 m/s² due to proper acceleration, not because one is in an accelerated frame of reference. The conversation emphasizes that free-falling objects follow geodesics and feel no force, while gravity is a manifestation of spacetime curvature, not a traditional force. The discussion also highlights the misconception that gravity is an inertial force, clarifying that the sensation of weight is due to the ground's resistance to free fall.
  • Understanding of General Relativity (GR) principles
  • Familiarity with the concept of geodesics in curved spacetime
  • Knowledge of proper acceleration and inertial frames
  • Basic grasp of the relationship between gravity and spacetime curvature
  • Study the concept of geodesics in General Relativity
  • Learn about proper acceleration and its implications in GR
  • Explore the effects of spacetime curvature on gravitational phenomena
  • Investigate the differences between inertial and non-inertial frames in GR
Students and enthusiasts of physics, particularly those interested in General Relativity, as well as educators and anyone seeking to deepen their understanding of gravity and its implications in modern physics.
Aerodyn
Hi everybody.
I recently started to learn GR from a very begginer level. I would like to share with you some lines of discussion, to understand your approach to some specific topics which for me are key to better understand the whole story.
If a put an accelerometer on the floor it reads 9.8 m/S2. Does it mean I am in an accelerated frame of reference? Here on Earth surface
When objects are in free fall, they feel no force does it mean that it is on a geodesic curve? If I see them accelerating towards the ground and they are inertial, does it mean that I am accelerated?
Is gravity an inercial force we feel because of the aceleration of our frame of reference here on Earth surface?;on the radial direction pointing outside (the acceleration).
So gravity is just inertia, the same force that we feel backwards when we accelerate a car, o turn?
How is this aceleration no affecting the size of Earth (outwards aceleration of Earth surface)
Thank you everybody for this great forum
Regards,
Aerodyn
Likes PeroK
No. It means you have a proper acceleration of 9.8 m/s^2. It is a very common misconception to use language such as "am I in X and Y frame of reference?"
First of all, frames of reference in Special Relativity typically refers to inertial frames. Second, nobody "is in" a particular reference frame. Any object will be in all reference frames - however it will be stationary in its rest frame. Finally, accelerated frames are not as unambiguous in special relativity (and certainly not in general relativity) as they are in Newtonian mechanics. In order to talk about them reasonably one needs to be very careful in specifying what is intended by the phrasing.
Yes, this is what free fall means.
Yes. Although technically it is the ground that has the proper acceleration. The falling object is in free fall.
In general relativity, gravity is not a force at all. It is the effects of the curvature of spacetime.
The locally experienced gravitation works much like that yes. However, that is not the full extent of the concept of gravity, which also includes how energy, momentum, and stress curves spacetime.
Spacetime is curved. This means that you can have locally accelerated paths that do not deviate from each other. This is similar to latitudes on a sphere that are locally curved (except the equator, which is a geodesic) away from the equator yet still maintains the same distance to it.
Then probably A-level is not the level you want to select for your thread. Doing so indicates that you have graduate level knowledge of the subject and would like answers geared at that level of understanding.
Likes Aerodyn, protonsarecool and vanhees71
Moderator's note: Thread level changed to "I" based on this.
Likes vanhees71
No, but it does mean that any frame you can sensibly describe as your rest frame is a non-inertial frame. You do often see this written as "you are in a non-inertial frame", but that's sloppy terminology that is likely to mislead you. You are free to use any frame (or, better said, any coordinate system) whether you are at rest in it or not.
Likes vanhees71
This is a good question. Basically, proper acceleration in a given direction does not imply absolute motion in that direction. Instead it implies changing relative motion between the accelerating object and a local inertial object. To understand the global picture, of course, you need the concept of curved spacetime. This allows two objects on opposite sides of the Earth to be constantly accelerating in opposite directions, but having no relative motion.
Thank you very much for your ideas. (Sorry for the mistakes).
I have serious lack of root knowledge, but for me is incredible to think how can the curvature of the space make us feel this "force". How the curvature is transferred to the fact that we feel a force down. I think I should read good about proper acceleration as you mentioned. I am very Newtonian!
I also liked the comparison with the latitude in the sphere
Thank you very much for your feedback, also more ideas are welcomed.
Regards,
Aerodyn
It is not the curvature itself that transfers to that, it is the fact that the ground is preventing you from following your free fall geodesic. Much like, as you said, a car seat prevents you from staying behind the car when the car accelerates.
Likes dextercioby and vanhees71
Aerodyn said:
I have serious lack of root knowledge, but for me is incredible to think how can the curvature of the spaced make us feel this "force,". How the curvature is transferred to the fact that we feel a force down. I think I should read good about about proper acceleration as you mentioned.
It doesn't make you feel a force. The only force you feel is the floor pushing up on your feet. That's why being in an accelerating lift, its floor pushing up on your feet, is indistinguishable from gravity locally. The curvature just changes the definition of "straight line" so that your natural movement is a curve downwards unlike in Euclidean space.
Likes vanhees71
As others have commented, you do not feel a force down. If you are moving solely under the influence of gravity, you feel no force at all. Astronauts on the International Space Station, for example. The force you feel standing on the surface of the Earth is up, not down, and is due to the ground pushing on your feet.
Likes Demystifier and vanhees71
In GR gravity isn’t a real force. So you don’t feel a force down. The only real force you feel is pressure from the ground pushing up, so you accelerate up as indicated by an accelerometer.
The curvature does not press you down, it just keeps the surface of the Earth from expanding despite its acceleration outward.
Likes vanhees71
And this pushing is mostly due to the electromagnetic interaction as well as the fact that matter consists of fermions.
Likes Demystifier
  • · Replies 69 ·
  • · Replies 78 ·
  • · Replies 36 ·
  • · Replies 55 ·
