General Solution to time independent schrodinger equation
The discussion focuses on deriving the general solution to the time-independent Schrödinger equation for an infinite square well, specifically in the form of u = A cos(kx) + B sin(kx). The initial confusion arose from the incorrect labeling of integration constants, leading to the misunderstanding that A exp(ikx) + B exp(-ikx) could be directly equated to A cos(kx) + B sin(kx). Participants clarified that using distinct constants C and D for the exponential form resolves the issue, allowing for a correct relationship between the constants and the desired trigonometric form.
  • Understanding of the time-independent Schrödinger equation
  • Familiarity with Euler's formula and complex exponentials
  • Knowledge of trigonometric identities and their applications
  • Basic concepts of quantum mechanics and wave functions
  • Study the derivation of the time-independent Schrödinger equation in quantum mechanics
  • Learn about the application of boundary conditions in solving differential equations
  • Explore the relationship between complex exponentials and trigonometric functions
  • Investigate the implications of using different constants in mathematical solutions
Students and educators in physics, particularly those studying quantum mechanics, as well as mathematicians interested in differential equations and their applications in physical systems.
hhhmortal
This is really a maths problem I'm having.
I need to get the general solution for the infinite square well in the form:
I found the general solution to be:
u = A exp(ikx) + B exp(-ikx)
Using Euler's formula:
exp(ikx) = cos(kx) + isin (kx)
exp(-ikx) = cos(kx) - isin(kx)
Hence, general solution becomes :
u = A cos(kx) + Bcos(kx)
What am I missing out?
Show how you got from the exponential form to the double cosine form. I have a feeling you think that A sin x- B sin x=0.
Yes you're right! That was a mistake I've made:
Instead I get:
u = (A + B) cos(kx) + (A - B) i sin(kx)
I still don't know how to get the correct form from this..
The problem you're having is that you labeled the integration constants for both types of solutions the same. This causes confusion.
Instead use u=C e^{ikx}+De^{-ikx} and find a relation between C,D and A,B (just relabel A and B in post #3).
I'm not sure what you mean. How would changing A & B to C & D make a difference?
Because the A in your first equation is not necessarily the same as the A in your second equation (post #1). Using the same name for different constants gets you into trouble. Just use the u given in my post with constants C and D and find a relation between those and A and B.
Forgive me for asking again. I seem to be confused over something so simple.
I did as you said..I think and got:
C exp(ikx) = A cos(kx) + iB sin(kx)
D exp(-ikx) = A cos(kx) + iB sin(kx)
What people are trying to tell you is that Ae^{ikx}+Be^{-ikx} \ne A\cos(kx)+B\sin(kx). You can't get one from the other because they're not equal to each other. You can, however, show that Ce^{ikx}+De^{-ikx} = A\cos(kx)+B\sin(kx) if you choose A and B correctly. Remember that C and D are arbitrary constants. Any combination of them will just be another arbitrary constant.
My previous post was wrong, sorry, is it simply:
C exp(ikx) = C cos(kx) + iC sin(kx)
D exp(-ikx) = D cos(kx) - iD sin(kx)
So,
C+D = A
(iC - iD) = B
Therefore:
C exp(ikx) + D exp(-ikx) = A cos(kx) + B sin(kx)
Yup, you got it.
Thanks for the patience everyone
  • · Replies 63 ·
  • · Replies 17 ·
