Generator var import and export
  • Thread starter Thread starter Pr0t0typ3
    Generator
4 replies · 6K views · last reply
Pr0t0typ3
Hi.
I'm working with this, so I should actually know this already, but... :P
I'm just not sure how this actually works.
Googled a little and found this forum with a good thread https://www.physicsforums.com/showthread.php?p=3973084
But for me, this is too much math. Can someone explain this a little easier for me? Almost i laymen term?
In the switchboard I have DEIF protections (PPU3/GPU3), which I set up the protections for high voltage, var import, var export, reverse power etc.. I would really like to have a better understanding of what I do instead of doing it the way I do now. I have a "recipe" on how to set up the protections for this, but this is not telling me what I actually do :P
Since the drawings I work with is copyrighted, I can't upload this, but I guess it is the same more or less all over the world...?
The generators are energized (excitation), I got voltage, and I connect it to the switchboard... Setting up a PPU3 og GPU3 is not so difficult, but it would be nice to know some more when I get specific problems with for example loss of sensing to the AVR...
We use mostly DECS-100 for AVR with either, PPU3 (paralell protection unit) or GPU3 (generator protection unit)..
i don't know a thing about your model numbers
you haven't said whether you understand the magnetic circuit in an alternator.
and that's the key to understanding how they behave in parallel.
perhaps you'd post a picture of one , and ask some questions to guide the discussion?
Usual teaching practice is to jump immediately to phasor diagrams
but what Bassalisk and i did in that link you referenced is talk our way through some pictures he had, to paint a mental image of the magnetic flux from which the formulas naturally come.
unfortunately the links to them now give "not found" error.
In my day Basler was a friendly helpful outfit. I once called them and explained i was maintaining some of their equipment, and they sent me a package of helpful "how it works" info. Mind you that was ca 1975 and it was magnetic amplifier voltage reulators... try it and see if they're still the same friendly midwesterners they were then.
there's two 'next steps'
old jim
Well... Probably not in the same way you do. I'm more practical than theoretical you could say.
I mainly work on the switchboard, and not the generator. But it is in the switchboard I need to set up the protections and therefor I want to understand this a little more.
Had a Service Engineer from Basler with me once, but the AVR is not something i normally configure..
DECS-100:
http://www.basler.com/html/rscdecs100.html
GPU3:
http://www.deif.com/Default.aspx?id=15904&productID=PROD2176
PPU3:
http://www.deif.com/Default.aspx?id=15904&productID=PROD2097
