Given voltage, solve for unknown resistor in a circuit
In a circuit with a 3.5 kΩ resistor (R1) and an unknown resistor (R2) connected in series to a battery, the voltage across R1 is measured at 5.0 V while the total battery voltage is 8.0 V. The current through the circuit is calculated to be 0.0014 amps. Two methods for calculating R2 yield similar results: one gives R2 as approximately 2.21 kΩ and the other as about 2.14 kΩ. The slight difference is attributed to rounding and truncation errors in calculations. Maintaining precision in intermediate calculations is essential for accurate results.
acdurbin953
An ohmic resistor (R1 = 3.5 kΩ) and circuit element X are connected in series to a battery of unknown voltage V0. Circuit element X is of unknown resistance. It is observed that the absolute value of the voltage across resistor R1 is 5.0 V.
The battery voltage is measured and found to be equal to 8.0 V.
The resistance of X must be what?
V=IR
Found the current to be 0.0014 amps by doing 5.0 V/3500 kΩ
My trouble is that I have worked the problem, but have come up with 2 similar solutions that seem plausible.
Solution 1: 8V = 0.0014(R1+R2), solving for R2 gives 2.21kΩ
Solution 2: Since the total voltage is 8 and R1 is 5, R2 must be 3. So then 3V = 0.0014(R2), and solving for R2 gives 2.14kΩ.
Both attempts are so close together that I have no idea which is right! Are they both more or less correct and one is just more accurate than the other?
Both methods will give you the correct (same) answer if you pay attention to rounding and truncation issues.
Don't round intermediate values for calculation. Carry sufficient digits to ensure that rounding and truncation errors do not creep into your valid significant digits. Scientific notation can go a long way to help avoid tired calculator fingers from entering all those leading zeros :)
Thanks! I guess I shouldn't be so lazy. ha
