nickb145 said:
A wedge of mass m= 1kg that is initially at rest is driven up a friction less ramp by a horizontal force F=50N due to a small attached rocket. The ramp is equilateral, with sides of length 50m
[Q1.] What is the magnitude of the normal force exerted by the ramp on the wedge?
[Q2.] What is the speed Vt (top of the ramp i assume) of the wedge as it leaves the ramp?
That's a good assumption.
F=ma
Fx=mgsin(60)
Fnety=n-mgcos(60)
(Final velocity)^2 – (Initial velocity)^2 = 2 * acceleration * distance
You mean:
##\text{1. }F=ma\\ \text{2. }F_x=mg\sin\theta\\ \text{3. } F_{net,y}=N-mg\cos\theta\\ \text{4. } v^2=u^2+2ad##
I'm guessing from this that you have adopted a coordinate system where the +x direction points directly up the ramp and the +y direction points upwards perpendicular to the ramp?
... I'd take another look at equations 2 and 3, they are incomplete.
So i know an equilateral triangle has angles of 60*
Well done. If you didn't you could figure it from the "sum of the angles" rule.
The normal force of the block on the incline is:
F(normal) = mg*cosθ
= (1)(9.8)cos(60°)
= 4.9.
Good. Don't forget units. What about the contribution from the rocket?
Note: cos(60)=1/2
(b) The force of gravity acting on the block on the incline is:
F(gravity) = mg*sinθ
= (1)(9.8)sin(60°)
= 8.487
... this is the x component of the force of gravity?
Check the direction.
If +x points up the slope, which direction does the x-component of gravity point?
Don't forget units.
Note: sin(60)=(√3)/2
This implies that the net force is:
F(net) = F(push) - P(gravity)
= 4.9-8.487
= -3.58 N. Is this the same as the magnitude?
This is why you have to
understand what you have done.
What was the whole point of working out those trig things?
What does that minus sign mean?
Isn't 4.9N the normal force? How does that push the cart?
Using F = ma ==> a = F/m, the acceleration of the block is:
a = F/m
= -3.58/1
= -3.58 m/s^2 (down the incline).
Take care when you mix negative numbers in your descriptions - does the minus sign mean the block is picking up speed moving down the incline?
Is this more along the right track?
If i have the acceleration of -3.58 i can just find the final velocity with (Vf)^2 – (Vi)^2 = 2(a)(d)=18.9m/s
You have the wrong units for (d).
If the initial velocity is zero, then the final velocity will be negative.
What does that mean?
I think you need to be more careful in your setup - paying attention to directions.
Try sketching the situation, and drawing x and y-axis on your sketch as a guide.
