Graphics and Animation software recommendations
31 replies · 5K views · last reply
Sorry no time to do something custom but here is an example of what can be easily achieved:
https://chessboardjs.com/examples/3004
Note that the only code that has been written to achieve that is what follows, everything else is in the libraries.
JavaScript:
var board = Chessboard('myBoard', 'start')
$('#move1Btn').on('click', function () {
  board.move('e2-e4')
$('#move2Btn').on('click', function () {
  board.move('d2-d4', 'g8-f6')
$('#startPositionBtn').on('click', board.start)
PeroK said:
That's the plan: to learn HTML and JavaScript next. Started that today.
Excellent! The chessboard module I linked uses some modern concepts that you may not encounter for a while so I drafted something for you to crib as a head start below. Note that this is not going to work in Internet Explorer.
JavaScript:
// We are using ES6 imports so this needs to be inside script type="module" -
// this is handled automatically in CodePen.
import { Chessboard } from "https://cdn.jsdelivr.net/npm/cm-chessboard@3/src/cm-chessboard/Chessboard.js";
// Note we have also loaded the following module which creates the Chess global.
// https://cdnjs.cloudflare.com/ajax/libs/chess.js/0.11.0/chess.min.js
// Set up a 'game' in FEN.
const game = new Chess("8/8/8/8/8/8/8/1N6 w - - 0 1");
// Some moves in PGN.
const moves = "b1-c3,c3-a2,a2-c1,c1-b3,b3-a1,a1-c2,c2-a3,a3-b2".split(",");
// Select DOM element as a target.
const el = document.querySelector("#board");
// Set the sprites to use for pieces (the default doesn't work when loading from a CDN).
const url =
  "https://cdn.jsdelivr.net/npm/cm-chessboard@3/assets/images/chessboard-sprite-staunty.svg";
// Create the board.
const board = new Chessboard(el, {
  sprite: { url },
  // Move more slowly (default 300ms).
  animationDuration: 1000
// Log a move into the DOM.
function logMove(move) {
  document.querySelector("#moves").innerHTML += ` ${move.slice(-2)}`;
// Mark a move on the board.
function markMove(move) {
  board.addMarker(move.slice(-2));
// This function is declared asynchronous so we can use 'await'.
async function play() {
  // Log the initial position;
  document.querySelector("#moves").innerHTML = moves[0].substring(0, 2);
  // Set up the board then mark the initial position.
  await board.setPosition(game.fen());
  board.addMarker(moves[0].substring(0, 2));
  // Iterate through the moves.
  for (let i = 0; i < moves.length; ++i) {
    const move = moves[i];
    logMove(move);
    // Try to execute the move.
    if (!game.move(move, { sloppy: true })) {
      // Log an illegal move and stop playing.
      document.querySelector("#moves").innerHTML += " Illegal move";
      break;
    // The move was successful so execute the move on the board and mark the square.
    // Note that setPosition() returns a Promise that is resolved when the move is
    // complete, so wait for it before continuing.
    markMove(move);
    // Reset the game from the displayed board otherwise it will be black's turn!
    game.load(board.getPosition() + " w - - 0 1");
// Wait for a bit before we start moving things around.
const timer = setTimeout(play, 2000);
