Graphing Implicit Function: Find HTL & VTL
  • Thread starter Thread starter Light bulb
    Graphing Implicit
The problem involves graphing the implicit function defined by the equation (x^2 + y^2)^2 = 4xy. Participants are tasked with finding the derivative, identifying points with vertical tangent lines (VTL), and points with horizontal tangent lines (HTL).
  • Mixed
  • Participants discuss the derivative of the implicit function and explore its correctness. There are attempts to manipulate the derivative to find conditions for VTL and HTL. Some participants express confusion about the results they are obtaining and question their understanding of the tangent lines.
Guidance has been offered regarding factoring terms in the derivative and solving systems of equations for VTL and HTL. Participants are actively engaging with the problem, attempting different approaches, and sharing insights about the relationships between the equations.
Some participants mention specific points they believe correspond to HTL and VTL based on their graphing attempts. There is an acknowledgment of the complexity of the implicit function and the challenges in deriving the correct tangent lines.
Light bulb
Graph (x^2+Y^2)^2=4xy
A)Find Y'
B)Find all points that have vertical tangent lines.
C)Find all points that have horizontal tangent lines.
I feel like I'm going nuts on this problem, y' is (-x^3-xy^2+y)/(y^3+x^2y-x) right?
I used a graphing program and it looks like an 8 reflected over y=x, but I just can't understand why I'm not getting the right answers for the HTL and the VTL.
A)Find Y'
Your derivative is correct. Try factoring an x out of the first two terms of the numerator and a y out of the first two terms of the denominator and replace the x2 + y2 with square root of 4xy from the original equation and see if that helps.
alright ill give it a try
Im still getting stumped, if I do that, I can turn the top half into y=4x^3, and the bottom half into x=4y^3, but obviously those won't give me an answers, I've looked at the graph and there are HTL at (+-.66,+-1.16) and VTL at (+-1.16,+-.66)
Vertical tangent lines are where the denominator of the derivative, [itex]y^3+x^2y-x[/itex] is 0 and horizontal tangent lines are where the numerator of the derivative, [itex]-x^3-xy^2+y[/itex] is 0. For each of those, you still have [itex](x^2+y^2)^2=4xy[/itex] so in each case you have two equations to solve for x and y.
For vertical tangent lines solve the system
[itex]y^3+x^2y-x= 0[/itex]
[itex](x^2+y^2)^2=4xy[/itex].
For horizontal tangent lines solve the system
[itex]-x^3-xy^2+y= 0[/itex]
You're on the right track. For the horizontal asymptote given as [itex]y=4x^3[/itex] you need to solve is simultaneously with the curve [itex](x^2+y^2)^2=4xy[/itex] as hallsofivy has said.
Same thing goes for the vertical asymptote.
ahh ill give it another try, thanks guys
A little additional point: The first equation for vertical tangent lines can be written as [itex]y^3+ x^2y- x= y(y^2+ x^2)- y= 0[/itex] so [itex]x^2+ y^2= y/y= 1[/itex]
I had to talk a little break from it but I just came back to it and got it right, thanks pf!
