Gravitation between two spheres
The discussion revolves around calculating the final speeds of two solid spheres with masses of 20.0 kg and 50.0 kg, respectively, when they are released from a distance of 30.0 cm apart and allowed to collide due to gravitational attraction. The potential energy was calculated using the formula U = -Gm1m2/r, yielding values of -2.22e-7 J initially and -3.34e-7 J when the spheres are 20 cm apart. By applying the conservation of energy principle, the total kinetic energy when the spheres make contact was determined to be 1.12e-7 J. The final speed of the smaller sphere was calculated to be 3.58e-5 m/s, with the method confirmed as valid.
  • Understanding of gravitational potential energy and the formula U = -Gm1m2/r
  • Knowledge of conservation of energy principles in physics
  • Familiarity with kinetic energy calculations, specifically KE = 1/2 mv²
  • Basic understanding of momentum conservation in closed systems
  • Study gravitational potential energy calculations in different contexts
  • Learn about conservation of momentum and its applications in collisions
  • Explore advanced kinetic energy problems involving multiple bodies
  • Investigate the effects of varying masses and distances on gravitational interactions
Students studying physics, particularly those focusing on mechanics and gravitational interactions, as well as educators seeking to clarify concepts related to energy conservation and momentum in collisions.
dzidziaud
Hello, I'm new here :) I'm stuck on a homework problem, even though it's probably really easy and I'm just being stupid.
In outer space, two solid spheres of radius 10.0 cm are held 30.0 cm apart center to center. One has a mass of 20.0 kg while the other has a mass of 50.0 kg. They are then released. Ignoring all forces except the mutual gravitational attraction of the two spheres, what is the speed of each sphere when they make contact?
U = -Gm1m2/r
So I found the potential energy before the spheres are released by using the equation above. I got -2.22e-7 J. When the spheres make contact, the centers are 20 cm apart, so I found the potential energy at r=20cm, and got -3.34e-7 J.
Then I used conservation of energy: KE1 + U1 = KE2 + U2. The initial KE was 0, so the KE when the spheres make contact is U1-U2 = 1.12e-7 J. So that is the total kinetic energy when the spheres make contact.
What I don't know is how to find the kinetic energy of EACH sphere individually. I thought that it would be proportional to their masses, but then I end up with a redundant answer where the masses cancel out and the velocities are equal, which I don't think is right.
What about the momentum of the entire system?
I don't know :( Are you saying that momentum will be the same before and after collision? But using that turns into an ugly system of equations that requires me to use the quadratic formula. Is there no simpler way?
What is the total momentum at the very beginning, not at the collision?
WHOA. It's zero. So m1v1=-m2v2. So v1 = -m2/m1v2. Okay. That makes things a lot easier :) So now KE of m1 = 1/2(m1)(m2^2/m1)(v2)^2 and KE of m2 is just 1/2(m2)(v2)^2. Putting that together, I get that the final KE, which I got above to be 1.12e-7, = 1/2((m2)^2/m1)(v2)^2 + 1/2(m2)(v2)^2. Solving for v2, I got 3.58e-5 m/s. Finding v1 from that will be simple. Is that right? :D
I have not checked the numbers, but the method is good.
Ok. Thanks so much!
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 21 ·
