Gravitational potential energy
The discussion centers on how gravitational potential energy (PE) changes as the height of an object increases beyond the Earth's radius. As the distance from the Earth's center increases, the gravitational potential energy, represented by the equation -GM/r, approaches zero, indicating that PE increases towards its maximum value. The graph of gravitational potential energy versus height is described as a rectangular hyperbola. The conversation also touches on the law of conservation of energy, emphasizing that energy transitions between forms without being created or destroyed. Overall, the relationship between gravitational potential energy and distance highlights fundamental principles of physics.
heinrich
if we think the height of a matter reaches over the radius of the Earth how will the potential energy of it change?
when height of it approaches infinite from zero how will be the graph of gravitational potential energy-height?
thank you
Is this homework? Do you know the equation for potential energy? Graph it!
edit: actually, since g changes with distance for large distances, you'll want to insert the equation for g into it.
Somehow I don't feel this was a HW question.
The PE of the Earth's grav field is -GM/r, where r is the dist from the centre. As r increases, GM/r decreases, and so -GM/r increases. As r tends to infinity, the PE tends to zero, which is the maximum value, through negative values, .
The graph between PE and r is a rectangular hyperbola.
the law of conservation of energy states that energy is never created or destroyed. it just changes from one form to another. good thing they invented negative energy to rescue this rule.
Actually, it sort of got invented by itself, when we called pull a negative push. :smile:
i agree with shooting star...you can easily see it from the work energy theorem...
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
