Gravitational Redshift really verification of GR?
thehangedman
If we assume:
E = mc^{2}
and for photons:
E = hv
Then we can derive an effective mass:
m = \frac{hv}{c^{2}}
And using simple classical gravity obtain:
hv - \frac{GMm}{r} = hv - \frac{GMhv}{c^{2}r} = Constant
You can derive the constant by evaluating the equation above at the limit as r goes to infinity. This then gives you the gravitational red shift, all without using anything from GR.
So, since this prediction is the same for classical AND GR, how can red shift be used as verification of GR? I'm not questioning GR, just wondering why this is still listed as verification when it's clearly not.
thehangedman said:
If we assume:
E = mc^{2}
and for photons:
E = hv
That's not correct. The gravitational redshift factor corresponds the to change in gravitational time dilation \frac{d\tau}{dt}-1=\frac{1}{\sqrt{1-\frac{2GM}{rc^2}}}-1.
If you are referring to the Pound and Rebka experiment, it proves gravitational redshift but it does not prove the validity of the Schwarzschild solution (even when we ignore rotation) as the experiment is not accurate enough to do that.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
