Gravitational Time Dilation on Mountaintops: New Member Questions
The discussion revolves around gravitational time dilation, particularly its implications at different altitudes, such as mountaintops compared to sea level. Participants explore the concept of time flow and aging in relation to gravitational fields, touching on both theoretical and experimental aspects.
  • Experimental/applied
  • A new member questions whether the cumulative effect of time flowing faster on mountaintops would result in a significant time difference over millions of years.
  • Some participants assert that while clocks on mountaintops would be ahead if not corrected, they would not imply that the Earth is in a future location.
  • There is a discussion about whether the concept of time and aging are fundamentally different, with some suggesting that aging is what runs slower in stronger gravitational fields.
  • A participant references an experiment involving cesium atomic clocks on Mt. Rainier to demonstrate the effects of gravity on time, highlighting the practical implications of gravitational time dilation.
  • Another participant challenges the simplification of aging as related to space movements in time, emphasizing the complexity of how aging is determined by the length of worldlines in spacetime.
  • It is noted that the Earth's core is estimated to be about 2.5 years younger than the surface, which ties into the discussion of aging and time differences.
Participants express differing views on the relationship between time and aging, with no consensus reached on whether they are fundamentally different concepts. The discussion remains unresolved regarding the implications of gravitational time dilation over long periods.
Some claims depend on specific definitions of time and aging, and the discussion includes unresolved mathematical steps regarding the implications of gravitational effects on time measurement.
jeepdriver74
New member here; just a physics hobbyist. There is probably a simple answer to this question but I could not find it. We know time flows faster on mountaintops relative to sea level due to gravitational time dilation. Over millions of years, wouldn't there be a cumulative effect making the mountaintop several seconds to minutes ahead in time compared to sea level? The Earth would be in a future location and rotational position causing some strange effects, which obviously does not happen.
No, it would not. The top would just be a bit different in age.
Well, clocks on the mountaintop would be ahead if they weren't corrected.
No. If clocks on the mountaintop see the sun at its zenith, so do clocks at sea level. They can exchange messages to confirm this. They won't agree on the elapsed time between successive noons by about one part in ##10^{13}## (assuming a 1km high mountain) but that's all.
Oh right. That's where I went wrong. Thank you.
Does this imply that what runs slower in stronger gravitational field is not Time, but Aging? These two are very different things.
Setting aside whether or not time and aging "are" very different things, can you point to any observable phenomenon that be diagnostic of a difference?
I post this every few years because it's just so cool.
http://leapsecond.com/great2005/
"In September 2005 the kids and I took several very accurate cesium atomic clocks from home and parked 5400 feet up Mt Rainier (the volcano near Seattle) for a full two days. The goal was to see if the clocks actually gained time, even if billionths of a second, as predicted by Einstein's general theory of relativity. Does gravity really alter time and can this weird phenomenon be detected with a family road trip experiment?"
Yes.
  • Love
Very cool!
DaveC426913 said:
Setting aside whether or not time and aging "are" very different things, can you point to any observable phenomenon that might manifest such a difference?
Well, for one, many celebrities are aging much slower than me, although we are supposedly living in the same time :).
Joke aside, aging of matter is related to space movements in time and as such can be slowed down or sped up.
This is too simplistic. For some special situations, such as an idealized isolated massive body like a planet and objects moving in the space surrounding it, it works, but it does not generalize.
The general rule is that "aging of matter" (or more precisely differences in aging of matter) only has meaning in the first place if two pieces of matter separate, and then come back together again later. In that case, the piece of matter whose worldline through spacetime from the separation event to the coming back together event has a longer length will age more. In other words, "aging" is driven by "length of worldline through spacetime".
It's estimated that the Earth's core is about 2.5 years younger than the surface.
Not really. Aging, or elapsed time, is a measure of the "length" of a path through spacetime since some chosen event. In flat spacetime you can only get different lengths between events A and B if at least one of the paths isn't inertial, so what you say is sort of true there although not well phrased. But in curved spacetime there is a much wider range of options for ways to achieve differences, including just hovering at different altitudes.
  • · Replies 79 ·
  • · Replies 54 ·
  • · Replies 55 ·
  • · Replies 58 ·
  • · Replies 16 ·
