Gravitational waves - second question
tonyb1969
Gravitational "waves" - second question
Assuming our concept of the universe expanding (perhaps) and that the fabric of space time is expanding at the same rate as our galaxy and solar system (velocity equal, so relatively motionless), would we still be able to detect gravitational waves when a planet (Earth, for example) accelerates around the Sun?
Your question includes internal inconsistencies and I have no idea what "velocity equal so relatively motionless" means.
Our galaxy is NOT expanding to any appreciable nor measureable degree. Only at (great) cosmological distances is dark energy (the cosmological constant) large enough to over come gravity and enable spacetime to expand. At ginormous distances from us, galaxies are receding at greater than the speed of light and hence gravitational waves from those galaxies will never reach us., nor will anything else; locally gravitational waves should always reach us unless the cosmological contant grows in the future to such a degree that, say, the sun and Earth move away from each other at greater than light speed.
If that doesn't not make enough sense try wikipedia at
http://en.wikipedia.org/wiki/Observable_universe
and note other wiki sources to the right under the box PHYSICAL COSMOLOGY. Beware "horizons" in cosmology are not immediately obvious.
While I personally like the idea of an ether, most say the "fabric of space" is just a metric. I would think the influence of gravity is present from any matter in the observable universe but in most cases would be too small to detect. Naty1 did well pointing out if you can't see the light, you will not feel the gravity.
Sincere thanks for overcoming the naive challenge of my question (I was having a hard time knowing how to word it). Your explanation, though, did answer what I was trying to get at. I'll also look on wikipedia as suggested...thanks...
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
