Is Special Relativity the Key to Understanding Shrinking Circles?
  • Thread starter Thread starter yourdadonapogostick
    Gravity Length
The discussion centers on the implications of special relativity on a spinning circle, where the radius remains constant while the distance between points on the circumference appears to decrease due to gravitational effects and acceleration. The author questions the constancy of π in this scenario, suggesting that as the circle spins, it may not maintain its traditional geometric properties. They note that the equivalence principle does not apply in this case, leading to a paradox reminiscent of the historical context that influenced Einstein's exploration of non-Euclidean geometries. This inquiry highlights the complexities of applying special relativity to geometric shapes in motion. The conversation underscores the intriguing relationship between physics and geometry.
yourdadonapogostick
am i missing something here?
we have a circle: (x-h)^2+(y-k)^2=r^2 where (h,k) is the center and r is the radius. we now spin the circle about an axis that is perpendicular to the plane on which the circle lies and it runs through the center of said circle. gravity contracts length (and my the equivelance principle, so does acceleration), so as the 1-sphere spins about the axis, the distance between any two points on it decreases while the radius stays the same. since \pi=\frac{c}{2r}, where c is circumference and r is radius, \pi no longer is a constant. the circle shrinks, but the radius stays the same. what is going on? does the circle turn into a cone?
Mathematics news on Phys.org
i just found out that the equivelence princliple doesn't apply here.
You have stumbled upon a fanatastic paradox of special relativity
As it appears in the history books, this is the very same case that lead Einstein to consider non-euclidean geometries in the physical universe.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
10K
