Gravity's Acceleration and its Effect
  • Thread starter Thread starter Greatness
    Acceleration
Gravity accelerates objects downwards at -9.8 m/s², but the upward force felt by standing individuals is due to the normal force from the ground, which counters gravity. According to Newton's Third Law, while gravity pulls you down, you exert an equal force upwards on the Earth, but this reaction is not felt. The sensation of weight is actually the result of the ground pushing up against you, not a reaction to gravitational pull. In a sealed environment, such as an elevator, distinguishing between gravitational pull and upward acceleration becomes impossible, illustrating that the feeling of weight is linked to the normal force. Ultimately, the experience of gravity is a balance of forces, primarily influenced by the normal force acting against gravitational pull.
Greatness
So, one of Newton's Laws of Motion is -F(sub)1 = F(sub)2.
Gravity is (generally) pulling us down with an acceleration of -9.8 m/s^2 where negative is downwards. Because of the above law, it has been said that this is felt upwards in objects. Why do I only feel gravity downwards?
Those forces act on different objects. Gravity pulls you down with some force; you pull the Earth up with the same force.
It is not felt upwards because of Newton's 3rd Law. When you are standing on level ground, there is a normal force from the ground on you which points upwards and tends to cancel the gravitational force, due to the Earth, pointing downwards from your center of mass. When you are walking on the surface of the earth, the ground pushes up on you and you will of course feel this; the normal force in such a scenario just happens to cancel out the force of gravity pulling you down, allowing you to stay on the level ground. This normal force however is not a reaction force due to the gravitational force exerted by the Earth on you! The reaction force of the Earth's gravity pulling on you is simply your gravitational force pulling back on the Earth.
As stated above, it is true that what you feel is the upwards pointing normal force from the ground on you. In fact, what Einstein said is that if you were completely sealed in a small elevator, you would have no way of telling if you and the elevator were at rest in a downwards pointing uniform gravitational field of magnitude ##g## or you and the elevator were accelerating upwards with magnitude ##g## in free space. This upwards acceleration of magnitude ##g## is what you feel. In the case of a person standing on the surface of the Earth, you feel the upwards normal force, since the ground is pushing up on you.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
