Gravity's Work on Mass Sliding Down Incline at 35 Degrees
The discussion centers on calculating the work done by gravity on a 50 kg mass sliding down a 2.0 m incline at a 35-degree angle. The initial calculations yielded a work value of 981, while the teacher's answer was 980, attributed to using g=9.8 instead of g=9.81. Participants suggest applying conservation of energy or the work-energy theorem for further analysis, particularly since friction is negligible in the second question regarding speed. The conversation highlights the importance of precision in calculations and the potential variations in gravitational acceleration based on location. Overall, the thread emphasizes understanding the fundamental physics principles involved in the problem.
._|evo|_.
A 50 kg mass is released from rest and begins to slide from the top of the incline (2.0 m). Th coefficient of kinetic friction between the mass and the inclines u
how much work does gravity do on the mass by the time it slides to the bottom of the ramp if the angle theta is 35 degrees?
W = f x d
F = m x a
W = (m x a) x d
First i found each following value:
m = 50
d = 2.0/sin(35 degrees)
a = 9.81 x sin(35 degrees)
Multiplied these all out, came with 981.
The answer the teacher says is 980 (he's a stickler to exact measurements)
something i did wrong?
Second question:
What is the speed of the mass by the time it slides to the bottom of the ramp if theta is 35 degrees, and the coefficient of kinetic friction between the mass and the incline is zero?
Related equations:
Um, not sure. Kinda stuck on this part lol.
Attempt:
Can't attempt without a solution.
The teacher used g=9.8 instead of g=9.81. Maybe, he lives on an other place on the Earth than you. :wink:
ehild
Apply conservation of energy (there is no friction) or the work-energy theorem. You know the work of gravity already.
ehild
  • · Replies 33 ·
