Can Laplace Transforms be Applied to Finite Intervals?
The discussion focuses on applying Laplace transforms to solve a boundary value problem for a string of length L under a load f(x). The equation to solve is Tu_{xx} = f(x) with boundary conditions u(0)=u(L)=0. The user struggles with their solution approach, particularly in using the delta function and the inverse transforms. They question the validity of applying Laplace transforms in a finite interval context and seek guidance on correcting their method. The consensus indicates that the standard Laplace transform technique may not be appropriate for finite intervals without additional modifications.
LCSphysicist
I don't know why, but my answer is wrong.
"Consider a string of length L that is connected at both ends to supports and is subjected to a load (external force per unit length) of f(x). Find the displcament u"
https://i.stack.imgur.com/yVIDG.png
We need to solve this:
$$Tu_{xx} = f(x)$$ subject to $$u(0)=u(L)=0$$
But i don't understand what is the problem in my solutions:
$$Tu_{xx} = f(x) = > Tu_{xx} = \delta({x-\epsilon})\\T(Us^2-su(0)-u_{x}(0)) = e^{-s \epsilon}\\U = (e^{-s \epsilon}/T + u_{x}(0))/s^2$$
So, we know that the inverse of $$e^{-s \epsilon}/(Ts^2) = H(x-\epsilon)x/T$$ and inverse of $$(u_{x}(0))/s^2 = u_{x}(0)x$$
So, shouldn't the final answer be $$u = \int_{0}^{L} f(\epsilon) (H(x-\epsilon)x/T + u_{x}(0)x) d \epsilon$$
Why is it wrong?
You have attempted a Laplace transform on a finite interval.
Hello. Thank you. But since we are restrict to a finite interval in x not infinite, this method is not possible? I mean, the method of find g using the delta dirac.
Or do i applied wrong? Could you give a tip to go on?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
