Green's function for an impulsive force on a string
13 replies · 3K views
xago
[PLAIN]http://img836.imageshack.us/img836/2479/stepvt.png
H'(t) = [itex]\delta[/itex](t)
So far I've taken the derivatives of G(x,t) with respect to xx and tt and gotten
[itex]G_{xx}[/itex](x,t) = -[itex]\frac{θ^{2}}{c}[/itex] and
[itex]G_{tt}[/itex](x,t) = [itex]θ^{2}[/itex]c
which gives [itex]θ^{2}[/itex]c - [itex]c^{2}[/itex](-[itex]\frac{θ^{2}}{c}[/itex]) = [itex]\delta[/itex](x)[itex]\delta[/itex](t)
= 2[itex]θ^{2}[/itex]c = [itex]\frac{dH(x)}{dx}[/itex][itex]\frac{dH(t)}{dt}[/itex]
where H(x), H(t) are the heaviside step functions for x and t.
I'm not sure how these are related or if I've gone about this in a completely wrong way. (Dirac functions are not my strong suit :frown: )
Is it possible that θ(ct-x) does not equal (θct - θx) which I assumed when I did the derivatives, but that theta is a function of ct -x ? In which case I'm really lost
Hi xago! :smile:
No, θ(ct-x) does not equal (θct - θx).
The first is zero for any x and t for which ct-x=0.
The second is only zero if x=0 and t=0.
I recommend working out the derivatives using product rule and chain rule.
You can use that dθ/dx=δ(x) and dδ/dx=δ'(x).
For the final expression you'll need some properties of δ in 2 dimensions to simplify it.
I don't understand how dθ/dx=δ(x)
For [itex]G_{tt}[/itex](x,t) I'm getting [itex]\frac{1}{2}[/itex][itex]\frac{d^{2}}{dt^{2}}[/itex](θ)(ct-x)cθ(x+ct) + [itex]\frac{d}{dt}[/itex](θ)(ct-x)[itex]\frac{d}{dt}[/itex](θ)(x+ct)c + [itex]\frac{1}{2}[/itex]θ(ct-x)[itex]\frac{d^{2}}{dt^{2}}[/itex](θ)(x+ct)c
For [itex]G_{xx}[/itex](x,t) I get pretty much the same thign except divied by c, [itex]\frac{1}{c}([/itex][itex]\frac{1}{2}[/itex][itex]\frac{d^{2}}{dx^{2}}[/itex](θ)(ct-x)cθ(x+ct) + [itex]\frac{d}{dx}[/itex](θ)(ct-x)[itex]\frac{d}{dx}[/itex](θ)(x+ct)c + [itex]\frac{1}{2}[/itex]θ(ct-x)[itex]\frac{d^{2}}{dx^{2}}[/itex](θ)(x+ct)c)
When I plug them into [itex]G_{tt}[/itex](x,t) - [itex]c^{2}[/itex][itex]G_{xx}[/itex](x,t) I get 2c[itex]\frac{d}{dt}[/itex](θ)(ct-x)[itex]\frac{d}{dx}[/itex](θ)(x+ct)
Looks good!
That's also what I have.
Here's a few more properties of delta (from: http://en.wikipedia.org/wiki/Dirac_delta_function" ).
[itex]\delta(x,y)=\delta(x)\delta(y)[/itex]
[itex]\delta(ax)={\delta(x) \over |a|}[/itex]
[itex]\delta(R(x,y))=\delta(x,y)[/itex] for any rotation or reflection R.
Well θ is a function of x and t right? So is take [itex]\frac{d}{dx}[/itex](θ)(x+ct) the same as δ(θ(x,t)) = δ(x,t) ?
or [itex]\frac{d}{dx}[/itex](θ)(x+ct) = δ(x)?
Not quite.
What you have is that θ'(y)=δ(y).
Applying the chain rule, you get:
[tex]{d \over dt}(\Theta(x+ct)) = \delta(x+ct) \cdot c[/tex]
Apparently you have already applied the chain rule, so you should just replace d/dt(θ)(x+ct) by δ(x+ct).
Edit: Note that δ(x+ct) is a one-dimensional dirac delta, while δ(x, ct) is a two-dimensional dirac delta.
Right so what I'm trying to do get rid of the 2c term somehow, what I'm getting is
2cδ(x+ct)δ(ct-x) which I need to make equal to δ(x)δ(t)
Yep.
Here's an alternative method to find it:
Let f(u,v) be an unspecified function.
Then:
[tex]\iint f(ct+x, ct-x) \delta(ct+x) \delta(ct-x) dxdt = \iint f(u,v) \delta(u) \delta(v) |\det(J)| dudv[/tex]
where J is the Jacobian matrix identified by the transformation from (u,v) to (x,t).
Since this equation holds for any function f, it follows that:
[tex]\delta(ct+x) \delta(ct-x) = \delta(x) \delta(t) |\det(J)|[/tex]
which leaves only the Jacobian matrix to be identified.
I understand it pretty good now, thanks for your help!
