Green's theorem, relation between two integrals
The discussion revolves around applying Green's theorem to evaluate a double integral over the unit disk. The initial attempt involved incorrect choices for the functions P and Q, leading to confusion in calculating the integral. After feedback, it was clarified that the correct functions should be P = xe^(xy) and Q = ye^(xy) to match the original integrand. The integrals were ultimately found to be zero once the appropriate functions were used. The importance of correctly selecting P and Q in Green's theorem applications is emphasized throughout the conversation.
mahler1
Homework Statement .
Calculate by a line integral the following double integral:
##\iint\limits_D (y^{2}e^{xy}-x^{2}e^{xy})dxdy##, D being the unit disk.
The attempt at a solution.
Well, if we consider C to be the curve that encloses the region D (C is the unit circle), then C is a simple, closed and smooth curve. Now, if we take ##F=(P(x,y),Q(x,y))##
with ##P(x,y)=-ye^{xy}## and ##Q(x,y)=-xe^{xy}##, then P and Q are ##C^1## functions. We are under the hypothesis of Green's theorem, so we know that the integral
##\iint\limits_D (Q_x-P_y)dxdy## equals the integral ##\int\limits_C Fds## where C is the unit circle. If I parametrize this curve in the standard way, I get ##ψ(t)=(cos(t),sin(t))## and ##ψ'(t)=(-sin(t),cos(t))## so the integral of the right member is
##\int_0^{2π} (-sin(t)e^{cos(t)sin(t)},-cos(t)e^{cos(t)sin(t)})(-sin(t),cos(t))
dt##, which is equal to ##\int_0^{2π} sin^{2}(t)e^{cos(t)sin(t)}-cos^{2}(t)e^{cos(t)sin(t)} dt##
I am totally stuck with this integral, I could express it by ##\int_0^{2π}e{cos(t)sin(t)}-2cos^{2}(t)e^{cos(t)sin(t)} dt## but I don't know how to solve it. Am I applying Green's theorem correctly or did I make a mistake in some previous step?
You've got a basic problem with your analysis and selection of the functions P and Q.
When you take your partial derivatives of P and Q and calculate (Qx - Py), you must obtain the original integrand of the double integral, namely (y^2EXP(xy) - x^2EXP(xy)). Have you checked this?
Likes 1 person
Use double angle formulas. Doesn't it sort of resemble cos(2t)e^(sin(2t))?
Likes 1 person
I see, P and Q were not the correct ones. I have to set ##P=xe^{xy}## and ##Q=ye^{xy}##. I spent like 15 minutes trying to find where my mistake was and I totally missed it.
The integral is 0, my problem was I hadn't chosen P and Q appropriately.
I think you still have P and Q incorrect. When you differentiate, the leading term must come out squared.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
