Grounding in Lab: ESD Protection Qs
  • Thread starter Thread starter fidel
    Grounding Lab
6 replies · 5K views
fidel
Hi all. We're moving to a new lab and I need to have a reliable ground for ESD protection, e.g. connecting the ESD mat safely. My questions are: can I just use the ground in the power outlet, or I need to request a different ground? Do I need to connect a resistor between the mat and the ground?
The mat should come with grounding instructions. Usually there will be a built-in resistor at the connection point, but you should check. You want a large value resistor (few hundred kOhm, I would think) to limit the current in the event of an electrocution hazard from equipment located above the mat.
The ground in an AC Mains socket should serve the purpose, once you've located the current limiting resistor.
You can buy special plugs that only have an Earth pin, contain a built in resistor and have the press-stud connector for a ground mat.
It's not especially important that the mat is grounded, just that your, wrist strap+bench mat+floor pad are connected together.
If you have an insulation tester or even an ohm meter it's worth checking the grounds of sockets in newly built labs are correctly earthed - it's amazing how many aren't, or have live/neutral swapped etc.
Well, to check the ground of the socket with an ohm meter, one probe to the "ground", how about another?
