- #1
Ruckus said:Thanks for your quick reply. How would I go on measuring it?
Ruckus said:I need to get a pump that would pump the same liters per hour as the tube or the tanks will overflow.
Nugatory said:Most reliable and affordable systems use a switch operated by a float to turn the pump on and off as needed to maintain a constant level.
Ruckus said:I haven't yet built it. Its for a rack of aquariums. Is there no formulas to work this out?
The appropriate inflow/outflow rate for a fish tank depends on the size of the tank, the type and number of fish, and the type of filtration system being used. Generally, a good rule of thumb is to have a turnover rate of 4-6 times per hour for freshwater tanks and 8-10 times per hour for saltwater tanks.
A balanced inflow/outflow rate helps to maintain a healthy and stable environment for your fish. It ensures that there is enough water circulation and oxygenation, while also removing waste and toxins from the tank.
The inflow/outflow rate can be adjusted by changing the settings on your filtration system or by using a flow control valve. You can also add or remove decorations or plants in the tank to alter the flow of water.
If the inflow/outflow rate is too high, it can cause stress to the fish and disrupt the balance of the tank. On the other hand, if it is too low, there may not be enough oxygenation and waste removal, leading to poor water quality and potential health issues for the fish.
It is recommended to check the inflow/outflow rate at least once a week and adjust it as needed. However, if you notice any changes in the behavior of your fish or the overall health of your tank, it may be necessary to check and adjust the rate more frequently.
