Gyroscope doubts. Please answer
  • Context: Graduate
  • Thread starter Thread starter Shivanand
    Doubts Gyroscope
The discussion revolves around the behavior of a spinning gyroscope, specifically a bicycle wheel mounted on a shaft. Participants explore questions related to the torques acting on the gyroscope, the conditions under which it remains stable or falls, and the relationship between angular velocity and stability. The scope includes conceptual understanding and technical reasoning about gyroscopic motion and forces.
  • One participant questions the relationship between gravitational torque and precession torque, seeking clarification on how these torques balance each other.
  • Another participant suggests that even if the gyroscope maintains a constant spin rate, it will still eventually tilt down due to gravitational effects.
  • Some participants express confusion about the conditions under which a spinning wheel supported at one end will fall, indicating that it may depend on initial conditions and the nature of the support.
  • There is a suggestion that the stability of the gyroscope does not depend solely on the angular velocity but also on other factors, including friction and the initial setup.
  • Participants discuss the importance of understanding the cyclical motion of the gyroscope and how it behaves as it loses energy over time.
Participants express varying viewpoints on the conditions affecting the stability of the gyroscope. There is no consensus on whether a critical angular velocity exists or how the gyroscope behaves under different support conditions. The discussion remains unresolved with multiple competing views.
Participants reference concepts such as torque, angular momentum, and the effects of friction, but there are unresolved assumptions regarding the definitions and relationships between these concepts. Some participants also mention Euler's equations, indicating a need for clarity on the application of these principles.
This discussion may be useful for individuals interested in understanding gyroscopic motion, torque dynamics, and the principles of rotational mechanics in physics.
Shivanand
Gyroscope doubts. Please answer :)
Consider the case of a common demonstration which you would find in videos. A bicycle wheel mounted on a shaft is set into rotation, axis is made horizontal and the shaft stays horizontal for sometime and eventually goes down as the wheel spin slows down due to friction.
Like this one : http://www.youtube.com/watch?NR=1&v=8H98BgRzpOM
My questions are
1) What torque balances the gravitational torque vertically and the precession torque horizontally (applying Newton's second law) ?
2) Let the torque resisting the vertical fall of shaft be R and torque due to gravity be T. Since the shaft finally tilts down is R more than T and why does this happen?
3) How is the resisting torque (against gravity) R dependent on
a)Rate of spin
b)Gravitational torque T ?
Please answer these questions :smile:
Shivanand, This question shows that you have a bit of misunderstanding with the concepts. Let's see if we can clear it up. Here's some questions for you:
a) What is the general relationship between torque and angular momentum?
b) There is a torque on the gyroscope caused by the downward force of gravity and the upward reaction force of the support. In what direction does this torque point?
c) What is the angular momentum of the spinning gyroscope? In which direction does it point?
d) Is the angular momentum constant? Remember it is a vector.
Also you mentioned Newton's Second Law. Does Newton's Second Law apply to torques or to forces?
...the shaft stays horizontal for sometime and eventually goes down as the wheel spin slows down due to friction.
No, even if the shaft continued rotating at the same speed (for example, if it were motorized) it would still slowly be pulled down.
It is against the rules for PF members to provide you with answers. You must show your attempts at the solutions before we can help you.
Hi,
Sorry for the late reply. I tried hard to understand and I thought I need help from people like you. I attempted to get a solution but I am too confused. Please excuse me for asking straight away and not posting my attempts in this thread :redface:
I will make my questions simple. If I could get an explanation, I would be able to understand. Please bear with me if my questions were/are annoying and if I seem like a noob. I am still learning.
1) Does a spinning bicycle wheel supported at one end of its shaft fall down if the rate of spin of the wheel (angular velocity) is constant?
2) If it does not fall down, is there a critical angular velocity above which the shaft does not fall? Or do the wheel and shaft fall irrespective of angular velocity (high or low) of the wheel? :confused:
It was my mistake to have told Newton instead of Euler. I meant Euler's equations. Sorry for that :redface:
Shivanand said:
Hi,
It depends. But not on the spinning speed. Someone before gave you the answer. It is important you understand why to master properly the gyro behavior.
It can always fall down, without anything you can do against it by adjusting the angular speed.
Try to understand why (it's not so easy), then eventually come back.
It depends on the initial condition, but assuming no friction or losses, it won't truly "fall", but instead cycle up and down. Also it depends on what you mean by supported at one end. If the support is a string that is suspended from above, the end of the string will follow a circular path that varies in radius (see video #9 in the link below). If the support is an unmovable rod (or at least unmovable relative to the earth), like a gyroscope placed on a "tower", then the initial condition can be one where the wheel axis remains horizontal as it rotates about the rod support.
Video #9 on this web page shows the complicated motion of a gyro suspended at one end by a long string mounted to the roof of the room. The key point of this video is that even though gyro is losing it's rate of spin, once it establishes the cyclical pattern shown in the video, it's center of mass will not significantly move vertically (the professor mentions it remains on a horizontal plane). As the gyro slows, the cyclical pattern will just speed up, keeping the center of mass from moving vertically until eventually almost all of the energy is lost and then it will "fall". (The friction interference with the rate of precession will determine where the center of mass will tend towards).
http://www.gyroscopes.org/1974lecture.asp
  • · Replies 39 ·
  • · Replies 49 ·
  • · Replies 0 ·
  • · Replies 19 ·
