How Does Torque Relate to RPM in a Gyroscopic Exercise Tool?
  • Context: Undergrad
  • Thread starter Thread starter bobo105
    Exercise
The relationship between torque and RPM in gyroscopic exercise tools, specifically Powerball models, is defined by the torque generated at varying speeds. These tools can produce torque ranging from 32 ft-lbs to 35 ft-lbs at speeds of 9,000 to 13,000 RPM, with peak torque reaching up to 250 Nm (184.4 ft-lbs) for heavier models. The torque is zero until induced, and formulas such as T = I α and T = (mr²/2) × (ω/t) are essential for calculating the required torque at specific RPMs. Understanding these relationships is crucial for optimizing performance and addressing wear issues in the gyroscopic mechanism.
  • Understanding of gyroscopic motion and dynamics
  • Familiarity with torque calculations and formulas
  • Knowledge of angular velocity and its relationship to RPM
  • Basic principles of mechanical wear and friction in exercise tools
  • Research the formula T = I α for practical applications in gyroscopic tools
  • Explore the impact of mass and radius on torque requirements in exercise devices
  • Investigate the effects of wear on performance in gyroscopic exercise tools
  • Learn about advanced torque measurement techniques for high-speed applications
Engineers, fitness enthusiasts, and product designers interested in the mechanics of gyroscopic exercise tools and those looking to optimize performance and durability in such devices.
bobo105
I want to know the relationship between the resistive forces of a gyroscopic exercise tool and the revolutions per minute of the rotor.
It generates from 32lbs to 35 lbs of torque when speeds of 9,000 - 13,000 RPMs are reached. I assume this means 32 ft-lbs to 35 ft lbs of torque, however the torque is zero unless you try to induce a torque, so I assume this is peak torque.
http://www.basegear.com/powerballgyro.html
these powerballs are made primarily of metal and have twice the weight of "regular" Powerball models and are more challenging to operate since up to 250Nm of torque is produced (250Nm = 184.4 ft lb).
http://en.wikipedia.org/wiki/Powerball_(exercise_tool)
The interface between the narrow track and the ends of the gyro axis would wear out (loss of friction), resulting in an unusable powerball after a relatively short period of time. I don't know if this issue was ever fixed.
Thanks, but is there a formula that links the revs/min of the rotor of the gyroscope to the torque?
[tex]T = I \alpha[/tex]
[tex]T = \frac{mr^2}{2} \times \frac{\omega}{t}[/tex]
[tex]\omega = \frac{2 \pi R}{60}[/tex]
[tex]T = \frac{mr^2 \pi R}{60t}[/tex]
where R = revs/min, r = radius, m = mass, ω = angular velocity, t = time
So far I have found that a torque of 0.25Nm is required to rotate the gyroscope to 17000 revs/min in 1 second (with a mass of 0.45kg and a radius of 0.025m). However, I want to know, for example, how much torque is required to rotate the gyroscope at a constant 15000 revs/min.
  • · Replies 0 ·
  • · Replies 23 ·
  • · Replies 49 ·
  • · Replies 17 ·
