Hamiltonian does NOT equal energy?
  • Thread starter Thread starter nonequilibrium
    Energy Hamiltonian
The discussion clarifies that in a system with a rod rotating at a constant angular speed and a movable ring, the binding forces are rheonomic, which are a type of non-holonomic constraint. This rheonomic nature of the forces is cited as the reason why the Hamiltonian (H) does not equal the total energy (E) of the system. The relationship between the Hamiltonian and energy is explored through the Lagrangian formalism. The participants confirm that the distinction between H and E arises from the specific constraints applied to the system. Understanding these concepts is essential for accurately analyzing such mechanical systems.
nonequilibrium
Hello,
Just to be sure: is the following correct?
Imagine a long rod rotating at a constant angular speed (driven by a little motor). Now say there's a small ring on the rod that can move on the rod without friction. The ring is then held onto the rod by an ideal binding force (I don't know the correct term in English, a force that doesn't deliver virtual work). This ring, free to move along the rod, can be described using the Lagrangian formalism.
Now is it true that the binding forces are non-holonomic? And this is the reason why H \neq E? It seems like it anyway, but I remember reading a thread on here a while ago looking for simple systems for which H \neq E while all examples given were very mathematical and far-fetched in a physical sense, so this makes me a bit unsure about what I've written above, hence the double-check.
Oops, important EDIT:
"Now is it true that the binding forces are non-holonomic?"
I meant non-SCLERONOMIC, i.e. rheonomic.
mr. vodka said:
Hello,
Yes,the constraint forces are rheonomic and this is whry H\neq E=T+V
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
