Frequency of Resultant Periodic Function from Sum of Three Harmonic Functions
The discussion centers on determining the frequency of a resultant periodic function formed by the sum of three harmonic functions with frequencies p, 2p, and 3p. Participants suggest sketching the sinusoids and adding them graphically to identify the resultant frequency. A mathematical approach using trigonometric identities is also discussed, specifically focusing on the relationship between the sine functions. Ultimately, it is concluded that when sinusoids with frequencies that are integer multiples of a base frequency are added, the net frequency of the resultant function is equal to that base frequency, p. The solution emphasizes the periodic nature of waveforms and the importance of analyzing one complete cycle.
praveenpandiyan
three harmonic function of frequency p, 2p ,3p were added together. what is the frequency of resultant periodic function?
X=Asin(wt)
A-amplitude w-frequency
X=X1+X2+X3
need a hint ..
You could try sketching the 3 sinusoids, and then adding them graphically. Sum 2 first, then to that add the third, and look for the period of the resultant.
But I think you should be able to do this mathematically. Do you have an equation from trigonometry:
sin A + sin B = ...
yes sir but I don't hv known limits in Grapically ..only freq . so by trignometricaL relation i tried it( as u said) ..with sin A+sinB=(1/2)*sin((1/2)(A+b))*Cos((1/2)(A-B)). . i get in the form sin*cos+Sin(C)
AND no use of sin A*cosB.. how to proceed here
resultant frequency X=p. Any IDEA how they got it
now let B=2A when you are summing a frequency with its double frequency
So, you plot for just a few cycles. Periodic waveforms are repetitive, what happens during one period also happens during the next period, so you just need to discover the period, and shape of waveform for one cycle.
thanks Nas .. i got the solution...sinusoids having frequencies in integer multiple of (f) have net freq (f) when addded together..when i consider by t=1/f ..its pretty clear final net freq occur only after first signal ..so answer is P
  • · Replies 51 ·
  • · Replies 25 ·
