Harmonic Motion - Bungee Jumping
1 reply · 4K views · last reply
youngling
You (mass m) are chosen as the "test pilot" for a new bungee jump. When
you suspend yourself at rest from the bungee, you find that it stretches a
distance L under your body weight. The jump point is a height 6L above the
ground and the relaxed (unstretched length) of the bungee is 3L. Should you
make the test jump?
Variables: k - spring constant
L - distance from jump point
I think that's it...
Given: m - your mass
equilibrium length of bungee+mass: 3L + L = 4L
F = -kx
F = mg
x = A cos(wt + phase)
I have no idea but I know that we're dealing with a harmonic motion problem where the bungee cord acts as a spring, and I think we need to determine the amplitude so that we can see if the "lowest" endpoint of the oscillation is greater than 6L from the jump point... because if it isn't then SPLAT. However, I don't know where to start. I said that F = -kx - mg, and then set F = 0 and x = 4L for the equilibrium point and got that k = -mg/4L
You should rather think in energy terms - energy is stored in the cord when it is stretched. Check what extension is required to absorb all of the potential energy of the test pilot.
