Harmonic Motion of a pendulum Problem
6 replies · 3K views
MorganJ
1. Homework Statement
-A pendulum with a length of 1.00 m is released from an initial angle of 15.0 degrees.
After 1,000 seconds, its amplitude is reduced to friction by 5.50 degrees. What is the value of b/2m?
In simple harmonic motion, a simple pendulum ---> 2pi times the square root of length over g constant.
If it is released from an initial angle of 15 degrees, I believe I must do 1sin or cos15 degrees. If friction is involved, I guess I must use the sum of all forces which is tension and friction opposing one another? And what does "b" stand for?
b is a damping coefficient.
A coefficient of what?
damping. Basically it represents how quickly friction damps the amplitude. It is usually if not always on the numerator with mass on the denominator. That is because the heavier something is, the harder it is to stop.
Okay so 1 meter is my amplitude. I use 15 degrees for initial and afterwards 5.50 degrees. How do I go about this?
isn't one meter the length of the pendulum?
Yes it is. Is this the equation: x=Ae exp -b/2m*t(cos(wt + phi))?
