How can I solve for the sines and cosines in a harmonic oscillation problem?
The discussion focuses on solving for the sine and cosine values in a harmonic oscillation problem, specifically using the equations of Simple Harmonic Motion (SHM). Participants suggest starting with the relationship between forces and accelerations, leading to the equation cos(ωt_A) = 2cos(ωt_B). Additionally, they emphasize the importance of energy equations and the relationship between velocities to derive the necessary sine and cosine values. The overall consensus is that a systematic approach using these relationships will yield the required results.
  • Understanding of Simple Harmonic Motion (SHM)
  • Familiarity with energy conservation principles in physics
  • Knowledge of trigonometric functions and their applications in physics
  • Ability to manipulate equations involving forces and accelerations
  • Study the derivation of the equations for Simple Harmonic Motion (SHM)
  • Learn how to apply energy conservation principles to oscillatory systems
  • Explore the relationship between forces, accelerations, and velocities in SHM
  • Practice solving harmonic oscillation problems involving sine and cosine functions
Students and educators in physics, particularly those focusing on mechanics and oscillatory motion, as well as anyone interested in applying trigonometric functions to solve physical problems.
PhysicS FAN
An object of mass m=1kg is executing a simple harmonic oscillation. During its oscillation it passes from a point A at which the speed of the object is u=1m/s and the force that its acting on it is F=2N. When the object passes form point B is moving with a speed u'=2m/s and an acting force of F'=1N. What's the frequency of the oscillation and what's the biggest distance from the equivalence position.
T=2π/ω, ΔΚ= W, F=kd
First of all, I found a function of the distance of the object form the equivalence point in both cases. I got something like d=2d' where d is the distance at the first case and d' at the second. I did that because I wanted to find the frequency, and so first I need to find the period of oscillation. In order to find the period I need to know D ( T=2π √m/D ). I used energy theorems to get an other equation involving d and d' but I am stuck. I think that the problem is quite easy but I just can't get to the answer. Any Ideas?
##F = ma## is one idea.
It looks tricky. Not easy. But, maybe if you look at the equations for SHM, you could find ##\cos(\omega t_A)## and ##\sin(\omega t_A)## etc.
That might help.
That might help.
Yes I'll try that
PhysicS FAN said:
Yes I'll try that
Well, I can't find anything that way. I think the best way to approach it is energetically since D theoritically could be found this way.
It definitely comes out that way. You could start with the relationship between the forces implies the same relationship between the accelerations at ##A## and ##B##. So:
##\cos(\omega t_A) = 2\cos(\omega t_B)##
The relationship between the velocities gives you another equation for the sines. From these you should be able to solve for all the relevant sines and cosines.
You still need the energy equation and what you've got already. But, getting the value of the sines and cosines is key.
Thanks a lot you've been really helpful!
  • · Replies 18 ·
