How Do You Calculate Period and Frequency of a Harmonic Oscillator?
The discussion focuses on calculating the period, frequency, and angular frequency of a simple harmonic oscillator that completes four vibrations in 11.5 seconds. The correct period is determined by dividing the total time (11.5 seconds) by the number of cycles (4), resulting in a period of 2.875 seconds. The frequency is calculated as the inverse of the period, yielding approximately 0.348 Hz. The angular frequency is derived using the formula ω = 2π/T, resulting in approximately 2.188 radians per second.
  • Understanding of simple harmonic motion
  • Familiarity with the equations of motion for oscillators
  • Knowledge of frequency, period, and angular frequency
  • Basic algebra skills for manipulating equations
  • Study the relationship between period and frequency in oscillatory systems
  • Learn how to derive angular frequency from period
  • Explore examples of simple harmonic oscillators in physics
  • Investigate the effects of damping on harmonic motion
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to clarify concepts related to harmonic oscillators.
chocolatelover
Hi everyone,
Could someone please help me with this problem?
A simple harmonic oscillator takes 11.5s to undergo four complete vibrations.
a. Find the period of its motion
b. Find the frequency in Hertz
c. Find the angular frequency in radians per second
ω=2pi(f)
ω=spi/T
f=ω/2pi
t=1/f
a. ω=2pi/11.5=.546
f=.546/2pi=.858
t=1/f=1.166
b. f=.858
c. ω=.546
Thank you very much
Nope, doesn't look right.
So in order to go back and forth 4 times, it takes 11.5s, right? Your "period" is how long it takes to do this once.
Secondly, frequency in Hz is f = 1/T
Lastly, your angular frequency is w = (2*pi)/T
Thank you very much
Could you please explain to me how to find one of these? Once I can find one, I can find the others. It seems like there isn't enough information given, because the 11.5 s is not used in any of the equations, right?
Thank you
your period is 11.5s divided by 4, i think
once you'be found your period, do the inverse to get your frequency
divide frequency by 2pi, multiply by 60s to get rad/s
i think i am correct, try it
Thank you very much
Isn't 11.5 just the time or is that also the period?
Thank you
no i think the problems means that it makes 4 cycles in 11.5 seconds, so a period equals the time of one cycle, so in order to find period from the given time, divide time by 4. try it.
did it work out correctly?
Yes, that was correct
Thank you very much
Regards
no worries, glad to help
