Can a Damped Anti-Spring System Explode Under Certain Conditions?
The discussion centers on modeling a damped anti-spring system using a differential equation. The equation derived is d²y/dt² + 3dy/dt - 4y = 0, where the mass m is 1 kg, the damping coefficient b is 3 N/(m/s), and the anti-spring constant k is 4 N/m. The participants explore conditions under which the anti-spring may experience arbitrarily large displacements, concluding that specific initial conditions can lead to explosive behavior, while others can prevent it. The analysis emphasizes the importance of understanding the differential equation's solutions to determine stability and behavior of the system.
  • Understanding of differential equations, specifically second-order linear equations.
  • Familiarity with concepts of damping in mechanical systems.
  • Knowledge of spring constants and their effects on motion.
  • Basic principles of stability analysis in dynamic systems.
  • Study the solutions to second-order linear differential equations with constant coefficients.
  • Learn about the behavior of damped oscillatory systems and their stability criteria.
  • Research initial condition effects on system dynamics in mechanical systems.
  • Explore numerical methods for solving differential equations to analyze complex systems.
Physics students, mechanical engineers, and anyone interested in the dynamics of non-standard spring systems and stability analysis in mechanical systems.
jjark24
Imagine a fictitious universe where springs want to stretch: the spring force is proportional to, and in the same direction as, displacement from equilibrium. We'll call these anti-springs.
(a) Set up a differential equation modeling the motion of a damped anti-spring if the mass is m = 1 kg, the damping coefficient is b = 3 N/(m/s), and the anti-spring constant is k = 4 N/m.
(b) Are there any initial conditions that make the anti-spring 'explode' (i.e., experience arbitrarily large displacements)? If so, what is an example? If not, why not?
(c) Are there any non-0 initial conditions that keep the anti-spring from exploding? If so, what is an example? If not, why not?
No idea where to even start on this problem. Any help would be appreciated!
I know that (a) is d2y/dt2 + 3dy/dt - 4y = 0
so how about showing a), in thr normal world the spring force with damping is
ma = m d2x/dt2 = F = -kx -b dx/dt
in the ficticious world
m d2x/dt2 = +kx -b dx/dt
or
m d2x/dt2 b dx/dt -kx = 0
which lines up with what you have
now how about trying to solve the DE?
or if you don't want to solve the whole thing or its too difficult, test the intial behaviour for different initial conditions and consider the limiting behaviour as x gets large...
That's a good start. You're done with part (a). Now solve the equation. You need to analyze the solution to answer parts (b) and (b).
  • · Replies 131 ·
