Harmonics of a Noon Hour Whistle in a Closed Air Column
The problem involves determining the fundamental frequency and the next harmonic of a noon hour whistle, modeled as a closed air column with a length of 0.750 m. The speed of sound in air is given as 342 m/s.
  • Participants discuss the relationship between the length of the air column and the wavelength, with some suggesting to divide the length by 4 to find the fundamental frequency. Others question how to find the next harmonic and whether to multiply or divide frequencies.
There is active engagement with various interpretations of how to calculate the fundamental frequency and the next harmonic. Some participants have provided guidance on using the length of the tube to determine the wavelength and frequency, while others are seeking clarification on the steps involved.
Participants are navigating through the constraints of the problem, including the specific setup of a closed air column and the definitions of harmonics in this context.
dance_sg
A small town’s noon hour whistle is an air column 0.750 m long and closed at one end. Find the fundamental frequency and the next harmonic produced by this whistle when the speed of sound in air is 342 m/s.
f= v/λ,
would i first find the frequency, then divide that by 3 to get the 3rd harmonic? then take the same number i divided by 3, but divde it by two to find the second harmonic?
In the closed pipe, length of the pipe for the fundamental frequency is equal to λ/4.
The next harmonics is three times the fundamental frequency.
so divide 0.750m by 4 to find the fundamental frequency? then how would i find the necxt harmoinic?
No.
λ = 4* length of the tube.
so I am multiplying the wavelength by 4...
No. In the problem the length of the tube is given, not the wavelength.
If you see the stranding wave in the tube closed at one end, you can see that length of then tube is equal to λ/4.
so how do i solve for the wavelength then?
Wavelength = 4*length of the tube.
0.750 x 4 then..
dance_sg said:
0.750 x 4 then..
Use the relevant formula which you have mentioned, and find the frequency.
ok. so that would be the frequency. in the question tho it says find the next harmonic. how do i do that?
Next frequency is equal to three times the fundamental frequency.
ok. so multiply what i got for the frequency by 3.
Yes.
thank you so much
18K
