Having issues series resistive and reactive impedance matching
The discussion revolves around the challenges of series resistive and reactive impedance matching in an RF circuit, particularly in the context of a dual-band RF harvester. Participants explore various calculations and configurations related to impedance, resonance, and the effects of component values.
  • One participant calculates Q and resonance values, proposing specific inductance (XL) and capacitance (XC) values for a 900 MHz application, but finds discrepancies in impedance matching.
  • Another participant notes that the antenna is likely a quarter wave vertical with a presumed impedance of 50 Ohms, questioning the configuration of the matching network as it appears to step down impedance rather than step it up.
  • A different viewpoint suggests that adding signals at RF rather than DC might yield a higher RF peak voltage, although this approach requires further exploration.
  • One participant expresses uncertainty about how to add signals at RF due to their usual practice of doing so at DC, indicating a need to review relevant materials.
  • Concerns are raised about achieving consistent results compared to those presented in the referenced research paper, particularly regarding the complexity of the dual-band RF harvester circuit.
Participants express differing views on the configuration of the matching network and the method of signal addition, indicating that multiple competing perspectives remain without a clear consensus.
Participants mention specific component values and configurations, but there are unresolved assumptions regarding the antenna's impedance and the effectiveness of the proposed matching network. The complexity of the circuit analysis is also acknowledged.
mechorigin
Having issues with getting the same series resistive and reactive impedance of the coil and cap they did in the figures
reactance equations, angular frequency, and Q
The only thing I could think of was using Q=sqrt(6000/50)-1 = 10.9, which then gets me XL=545 and XC=550, or 96.4nH, and 0.32pF at resonance of 900Mhz. I tried seeing if Zin=Zout equation would bring me close, so I tried Z=545+(50-550)=45, then XL for 38.5nH was 217.7, and XC for 2.4pF was 74. Of course Z=217+(50-74) equals 193. so 45 does not equal 193. but then I realized there was an absorption method for the stray capacitance inherent in the diodes. totaling roughly 0.36pF for 0.18pF each diode. So from here I tried calculating the two capacitance I had as if they were in parallel, giving me around 0.68pF total. With an XL of 220, and XC of 260 I tried Z=220+(50-260)=10. Closer, but not quite. The full research paper I am referencing doing my homework on: https://www.aimspress.com/article/id/274
I think the antenna is a quarter wave vertical, presumably 50 Ohms, although I cannot see the impedance of the antenna stated. But I notice that the matching network shown, which is an L-match, is configured to produce a step down in impedance to the diodes rather than the required step up.
I also tend to think that it might be better to add the signals at RF rather than at DC. Adding the signals at RF gives a higher RF peak voltage.
Interesting, I could give that a try, although I will have to dig through my textbooks, I forgot how to add the signals at RF cause I usually do it at DC. Though I've never had to analyze something this complex before.
Yeah I would presume it was at 50 ohms as well, as well as the paper suggests it to be used with (~λ/4 at 900 MHz, and 2200?) and because the diodes have such a low forward voltage and the junction capacitance is roughly 0.18pF each, I would assume the matching circuit might have to match down as to not add more components due to parasitic effects.
Still having issues with getting the same results they did, especially in the dual-band RF harvester circuit.
  • · Replies 20 ·
10K
