Heart's Work Output: Viscosity & Vein Length
The discussion revolves around the work output of the heart, specifically in relation to factors such as viscosity, vein length, and the impact of height on circulatory work. Participants explore theoretical calculations and the complexities involved in accurately determining the energy required for the heart to pump blood.
  • One participant notes an example of the heart's work output being calculated as 2 watts based on height and blood volume, questioning the relevance of height in a closed circulation system.
  • Another participant agrees that height should not be a factor, stating that gravity is a conservative force and does not affect the work done by circulation.
  • A participant inquires about how to calculate the energy needed for the heart to pump blood, suggesting that viscosity and vein diameter could be considered for rough calculations.
  • Concerns are raised about the complexity of accurately calculating energy requirements due to factors like "minor losses" from changes in flow and geometry, as well as the non-linear relationship of wall friction with diameter and velocity.
  • It is suggested that rough calculations may yield results that are significantly inaccurate, potentially off by a factor of 100.
Participants express differing views on the relevance of height in calculating the heart's work output, with some arguing it should not be considered while others question the methodology of using viscosity and vein dimensions. The discussion remains unresolved regarding the best approach to accurately calculate the energy needed for the heart to pump blood.
Participants highlight limitations in calculating energy requirements due to the complexities of blood flow dynamics, including the effects of vein curvature and changes in diameter, which introduce significant uncertainties.
michaelwoodco
I saw an example where the work of a heart was found to be 2 watts based on the height of a person and the liters of blood that it pumped throughout the day. Since we have closed circulation systems (unless we have a cut, annerism, etc. ) I thought height would not matter, and in order to achieve the best accuracy we would consider instead viscosity and vein length. Or perhaps take the pressure difference before & after the heart at the current flow rate and you could use that to calculate the resistance to flow. In theory with no viscosity wouldn't our blood just flow forever because although on one side of the loop the blood has to go up against gravity on the other side gravity is pulling it down?
Yeah I don't see why they would take into account height. Gravity doesn't affect the circulation work done since it is a conservative force.
How exactly would I calculate the energy needed for the heart to pump blood then, take into account viscosity and vein length/diameter? I'm guessing I could make a rough calculation by using average vein diameter?
Eh, its too difficult since each time the flow changes diameters there is a "minor loss" which is based on velocity squared, geometry, etc.
And wall friction factor isn't at all linear with diameter or velocity, so taking an average will give a poor result. Curvature in veins also contributes to "minor losses" which are impossible to determine.
Doing a "rough" calculation will probably end up being off by a factor of 100.
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 33 ·
