Joker93
- Messages
- 502
- Reaction score
- 37
Sorry for being such a pain, but I don't understand what you are implying.Chestermiller said:W is equal to zero when V is constant, not P.
No problem. If the volume of a parcel of gas containing a constant number of molecules is constant, then it is not doing any work on the surrounding gas. If the volume of a parcel of gas containing a constant number of molecules is increasing, the parcel is doing work on the surrounding gas. So, at constant volume, work is being done, and, at constant pressure, work is being done.Joker93 said:Sorry for being such a pain, but I don't understand what you are implying.
In your last sentence, you meant "at constant volume, work is not being done", right?Chestermiller said:No problem. If the volume of a parcel of gas containing a constant number of molecules is constant, then it is not doing any work on the surrounding gas. If the volume of a parcel of gas containing a constant number of molecules is increasing, the parcel is doing work on the surrounding gas. So, at constant volume, work is being done, and, at constant pressure, work is being done.
Yes. Thanks.Joker93 said:In your last sentence, you meant "at constant volume, work is not being done", right?
Both ways of doing it are valid. However, you have to take into account that, during the process, once a parcel of mass has left the container, it no longer receives any of the heat the is still being added to the gas within the container.Joker93 said:@Chestermiller I tried to solve it in 2 ways: first considering a control volume inside the container so that ΔV=0 and ΔΝ not equal to zero. Second, I considered the whole control volume(also outside the container) so that ΔV not equal to zero and ΔΝ=0. Aren't both ways of doing it valid(I do not know the concept of enthalpy so I can not do it your way)?
Doing these two ways, I do not obtain the same answer. In the second case, for N=constant, I got that ΔQ and T are related linearly and not logarithmically.
But, the container is adiabatically isolated. So, the only heat flow in and out of the container(fixed control volume case) is due to mass flowing in or out of it.Chestermiller said:Both ways of doing it are valid. However, you have to take into account that, during the process, once a parcel of mass has left the container, it no longer receives any of the heat the is still being added to the gas within the container.
What do the words "The question was to find the heat that is needed to change that temperature." mean to you?Joker93 said:But, the container is adiabatically isolated. So, the only heat flow in and out of the container(fixed control volume case) is due to mass flowing in or out of it.
Sure. No problem.Joker93 said:@Chestermiller Can I write my two solutions so you can see what's wrong with them?
That I have to find the heat that is being transferred out of the system by the particles leaving it.Chestermiller said:What do the words "The question was to find the heat that is needed to change that temperature." mean to you?
That doesn't count as heat. The term heat is reserved for energy transferred across the boundary enclosing the system (excluding mass flow, which, of course, carries internal energy).Joker93 said:That I have to find the heat that is being transferred out of the system by the particles leaving it.
Thanks.Chestermiller said:Sure. No problem.
So, heat here is the heat that flows through the small hole through which the particles can pass?Chestermiller said:That doesn't count as heat. The term heat is reserved for energy transferred across the boundary enclosing the system (excluding mass flow, which, of course, carries internal energy).
No. The whole tank is being heated.Joker93 said:So, heat here is the heat that flows through the small hole through which the particles can pass?
But it says that the walls are adiabatically isolated.Chestermiller said:No. The whole tank is being heated.
Can you please provide the exact wording of the problem statement?Joker93 said:But it says that the walls are adiabatically isolated.
Of course. Here it goes:Chestermiller said:Can you please provide the exact wording of the problem statement?
This is a very ambiguous problem statement. Maybe they are thinking that there is an electric heater inside the container to heat the air and that no heat can be transferred to or through the walls of the container. There is certainly no way that the air in the container can have its temperature raised from 0 to 20 (at constant container volume) without adding any heat to the air. The given solution also certainly implies that the heat is added to the gas in the container.Joker93 said:Of course. Here it goes:
A quantity of air in equilibrium has pressure of 1atm in temperature of 0 celsius and volume 27m^3. Calculate the heat needed to heat up the same quantity of air in the following conditions:
The air is contained in a thermally insulated container of constant volume. A wall of the container has a very small hole on it that allows the "communication" of the air inside it with the outside air. The outside air has a pressure of 1atm. The air changes from 0C to 20C very slowly.
(I think that the last sentence might imply that the air is heated inside the container).
Okay, so assuming that this is what happens then, what is wrong with the 2 solutions I gave above?Chestermiller said:This is a very ambiguous problem statement. Maybe they are thinking that there is an electric heater inside the container to heat the air and that no heat can be transferred to or through the walls of the container. There is certainly no way that the air in the container can have its temperature raised from 0 to 20 (at constant container volume) without adding any heat to the air. The given solution also certainly implies that the heat is added to the gas in the container.
In method 1, you neglected the fact that, once a parcel of mass has left the container, it no longer receives heat. Only the gas that, at any instant of time still remains inside the container, receives heat.Joker93 said:Okay, so assuming that this is what happens then, what is wrong with the 2 solutions I gave above?
So, how do I include that effect?Chestermiller said:In method 1, you neglected the fact that, once a parcel of mass has left the container, it no longer receives heat. Only the gas that, at any instant of time still remains inside the container, receives heat.
I don't understand what you did in method 2. Certainly, if the temperature of the gas in the container is increasing, its internal energy E is increasing. After that step, I'm lost.
Joker93 said:So, how do I include that effect?
dV equal to zero does not mean that dE = 0. There is heat being added.In the second method, dV=0(the change in the volume of the control volume), so dE=0.
for the second method, i only used that PV=NkT and E=f/2*NkT. So, we get E=f/2*PV. Taking differentials: dE=f/2*PdV. I did not use the concept of work here.Chestermiller said:You are only heating the gas that is remaining within the tank. If n is the number of moles of gas remaining in the container at any time t, then $$dQ=nC_pdT$$This is combined with $$n=\frac{PV}{RT}$$ to give:$$dQ=\frac{PV}{RT}C_pdT$$
Ah. I see what you did in Method 2 now. It is very similar to what I did in post #14 (believe it or not). Your only mistake was leaving out the work taking place at the exit hole. Even though the rest of the tank is rigid, the gas in the tank is doing work to push gas out the exit hole (which is not a rigid boundary). If dn is the number of moles going out the exit hole between time t and time t + dt, the amount of work required to push this gas out the exit hole is Pvdn, where v is the molar volume of the gas at time t: ##v=RT/P##. So, the amount of work is RTdn.Joker93 said:for the second method, i only used that PV=NkT and E=f/2*NkT. So, we get E=f/2*PV. Taking differentials: dE=f/2*PdV. I did not use the concept of work here.
Also, before proceeding, I want to ask a conceptual question first. Is the temperature in the whole control volume the same as the temperature in the control volume that only covers the inside of the container?
Chestermiller said:Ah. I see what you did in Method 2 now. It is very similar to what I did in post #14 (believe it or not). Your only mistake was leaving out the work taking place at the exit hole. Even though the rest of the tank is rigid, the gas in the tank is doing work to push gas out the exit hole (which is not a rigid boundary). If dn is the number of moles going out the exit hole between time t and time t + dt, the amount of work required to push this gas out the exit hole is Pvdn, where v is the molar volume of the gas at time t: ##v=RT/P##. So, the amount of work is RTdn.
The equation should read: ##dQ=C_VTdn+Pvdn##. The first term represents the internal energy leaving the tank in the parcel dn, and the second term represents the work done to push the parcel dn out of the tank.Joker93 said:But, shouldn't this extra term come out naturally? In the solution I provided, I ended up with δQ+δW=f/2*k*NdT+f/2*k*TdN by only using that δQ+δW=0
and dE=f/2*k*d(NT)=f/2*k*(NdT+TdN). So, where would his extra term come up?
No. In the latter case, once a parcel leaves the tank, its temperature stops changing (assuming that it doesn't exchange heat with the outside air). So, for the whole control volume, the temperature in the tank is uniform (and equal to the temperature that we are solving for), but, for the parcels that have already exited the tank, their temperatures vary over the range from the temperature of the first parcel to leave the tank to the temperature of the parcel that just most recently left the tank.Also, before proceeding, I want to ask a conceptual question first. Is the temperature in the whole control volume the same as the temperature in the control volume that only covers the inside of the container?
I've understood that, but my problem is with how does it arise from the method of solution I am using. I mean, following the steps I am taking in method 2, where does the extra term show up that I neglected? I only used dE=δQ+δW and E=f/2*k*NT to arrive at the seemingly wrong δQ+δW=f/2*k*NdT+f/2*k*TdNChestermiller said:The equation should read: ##dQ=C_VTdn+Pvdn##. The first term represents the internal energy leaving the tank in the parcel dn, and the second term represents the work done to push the parcel dn out of the tank.
I can't go through the entire fixed control volume version of the first law, which is covered in detail in every thermodynamics book. But, for this problem, if we do an energy balance on the contents of the tank between time t and t + dt, we obtain:$$dE=dQ-dW-edn$$ where ##E=(nC_vT)##, dW is the work done to push the gas of mass dn out of the tank, and edn is the internal energy exiting the tank in the exit stream (e is the internal energy per mole of the exit stream). You have already shown that dE = 0. So, $$dQ=dW+edn$$The work to push the parcel of gas dn out of the tank is given by:$$dW=Pvdn=RTdn$$ So,$$dQ=(e+RT)dn=(C_vT+RT)dn=(C_v+R)Tdn$$Joker93 said:I've understood that, but my problem is with how does it arise from the method of solution I am using. I mean, following the steps I am taking in method 2, where does the extra term show up that I neglected? I only used dE=δQ+δW and E=f/2*k*NT to arrive at the seemingly wrong δQ+δW=f/2*k*NdT+f/2*k*TdN
From your last help, I tried something more familiar to me. I again wrote dE=dQ+dW but this time I wrote dW=μ*dN - W where W is the work done to push the gas out but in a form that implies a change in volume. To clarify, I wrote W=Pv*dN(as you did) which is like pushing small volumes v out of the fixed control volume. Also, μ is the chemical potential(like you said, the energy that gets transported outside the control volume) and it is equal to μ=dE/dN which gives μ=f/2*kT. So, dW=f/2*kT*dN + Pv*dN with v=V/N (note that I wrote +PvdN rather than -PvdN because when dN>0 then work is being done ON the system so dW>0 as opposed to the typical dW=-PdV).Chestermiller said:I can't go through the entire fixed control volume version of the first law, which is covered in detail in every thermodynamics book. But, for this problem, if we do an energy balance on the contents of the tank between time t and t + dt, we obtain:$$dE=dQ-dW-edn$$ where ##E=(nC_vT)##, dW is the work done to push the gas of mass dn out of the tank, and edn is the internal energy exiting the tank in the exit stream (e is the internal energy per mole of the exit stream). You have already shown that dE = 0. So, $$dQ=dW+edn$$The work to push the parcel of gas dn out of the tank is given by:$$dW=Pvdn=RTdn$$ So,$$dQ=(e+RT)dn=(C_vT+RT)dn=(C_v+R)Tdn$$
I'm running out of ideas on how to show this better. How does your analysis compare with this analysis?
