Heat energy dissipated from moving box with friction
The discussion focuses on calculating the rate of heat energy dissipation from a box weighing 40N, dragged at a speed of 1.5 m/s across a rough floor with a coefficient of friction of 0.20. The correct formula for power, derived from the work done against friction, is established as P = F * v, where F is the frictional force. The calculated power dissipation is confirmed to be 12W, using the equation P = μN * v, where μ is the coefficient of friction and N is the normal force.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of friction and normal force
  • Knowledge of power calculations in physics
  • Ability to interpret free body diagrams
  • Study the concept of free body diagrams in physics
  • Learn about the relationship between work and energy
  • Explore advanced topics in friction, including kinetic vs. static friction
  • Investigate the implications of power calculations in real-world applications
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding energy dissipation due to friction in practical scenarios.
Pete Panopoulos
A box of books that weighs 40N is dragged at a speed of 1.5 m/s across a rough floor. If the coefficient of friction between the floor and the box is 0.20, what is the rate at which heat energy is dissipated?
Friction: f=μN
Work: W=F*d
Power: P=W/t
[/B]
My assumption would be if the units of power are watts, or kgm2/s3, breaking that up would be :
kg*m/s2*m/s
and the box weighs 40N, so kg*m/s2=40, and v=1.5m/s
With the coefficient of friction being 0.20,
would the answer be 40*1.5*0.2= 12W ?
Friction: f=μN
Work: W=F*d
Power: P=W/t
[/B]
kg*m/s2*m/s
Your answer looks right, but rather than just doing the dimensional analysis, it would probably help you to draw a free body diagram. Later on, you will see vector equations for work where this dimensional analysis approach won't work.
For the free body diagram, you have gravity pushing down with a Force of 40N. This is compensated by a normal force of 40N (ground pushing up on the box). You know this, because there is no acceleration up/down.
There is also no acceleration forward-backwards. So the net force inthis direction is also zero. You are pushing the box forward with some force F->, friction is pushing back with an equal and opposite force <-F. The magnitude of the Frictional force is equal to the Normal Force times the coefficient of friction.
The work done is the force times the distance. The rate of energy lost to friction is equal to the work done divided by time.
I agree.
Work = force * distance
Power = work/time
so
Power = force * distance/time
or
Power = force * velocity.
Thank you very much!
10K
11K
