Heat equation and taylor's approximation
7 replies · 2K views · last reply
orangesun
storage of heat, T at time, t (measured in days) at a depth x (measured in metres)
T(x,t)=T0 + T1 e[tex]^{-\lambda} x[/tex] sin (wt - [tex]\lambda[/tex]x)
where w = 2pi/365 and [tex]\lambda[/tex] is a positive constant
show that [tex]\delta[/tex]T/[tex]\delta[/tex]t = k [tex]\delta[/tex]^2 T / [tex]\delta[/tex]x^2Derive the second order Taylor polynomial approximation Q(x, t) for T(x, t)
about the point (-0,1)
I'm sorry i have absolutely no idea how to even begin this question, i would really like it if someone could nudge me in the right direction for the method at least.
thanks heaps
for the first part i would start by attempting the required derivatives to see if the equality is true
I understand that, but I just don't know how you would even begin tackling this question.
How would you even be able to take the derivative of that function?
well you have T(x,t)
it should be stratightforward differentiation using chain rule to find
[tex]\frac{\partial T(x,t)}{\partial t}[/tex]
[tex]\frac{\partial^2 T(x,t)}{\partial x^2}[/tex]
as they are partial derivatives when you differentiate the other variables are kept constant
have a go and i'll help you
thanks heaps for that lane dance! I didnt know where to start but I managed to get an answer...for both dT/dt and dT/dx and just derive dt/dx again to get d^2T/dx^2
I just need a bit of help now with the second part, how would you use the taylor approximations for that
so what is the equation for a 2nd order taylor polynomial expansion of a 2 variable equation?
I know what it is for a 1 variable equation, but for a 2 variable equation I am a bit stumped.
is it where you have to replace Q(x,y) with x=a+h y=b+k ?
here's the first thing that pops up on a quick google on "multivariable taylor series"
http://www.fepress.org/files/math_primer_fe_taylor.pdf
