How Do You Calculate BTUs from Temperature Change in a Heat Exchanger?
drkidd22
Hello,
I'm working with a heat exchanger I'm trying to integrate into a cooling application. I've done some tests but want to have some clear understating of how the calculations are done or if I have missed something. Below is what I have so far.
So it's a radiation with 2 pwm fans, they push air through the radiator. It has a 1.7gpm water flow through the loop.
Air temp into fans: 30.1C
Air temp out fans (rear radiator): 59.2C
Input water temp to radiator: 64.8C
Output water temp from radiator:56.5C
So what I get from this is that the radiator is removing 8.3C from the water temp. How would this translate to actual power or BTUs dissipated by the radiator?
drkidd22 said:
1.7gpm water flow
Power? You want BTU/hr if you're interested in English units. What's the definition of BTU?
I have encountered a vertically oriented hydraulic cylinder that is designed to actuate and slice heavy cabling into sections with a blade. The cylinder is quite small (around 1.5 inches in diameter) and has an equally small stroke. The cylinder is single acting (i.e. it is pressurized from the bottom, and vented to atmosphere with a spring return, roughly 200lbs of force on the spring). The system operates at roughly 2500 psi. Interestingly, the cylinder has a pin that passes through its...
  • · Replies 34 ·
  • · Replies 17 ·
