Heat exchangers and energy balances
In summary: Correct. So what are you taking as the exit state of the F12 from the exchanger. There is definitely information missing from this problem. Are you sure you want to try to solve it?
saratavares
I have to do a project using Aspen and need to do some math before hand. Can you please help me? Here's the problem:
A heat exchanger with 10 m2 of heat transfer area is provided to supply 58 kW to a water stream available at 15 ° C and 1 bar. The available hot fluid is freon-12 at 32 ° C and 7 bar.
Determine the amount of water that can be heated and the freon flow required for the purpose.
Thank you so much!
Is the freon-12 a saturated liquid under these conditions? If so, are you going to assume that all the freon evaporates to form a saturated vapor at 7 bars?
More importantly, is this a homework problem?
Hello. Yes it's a saturated liquid under these conditions, and yes I think it will all evaporate. It's not a homework problem, it's a project I have to do for University at the end of the semester. I have few time to do it and I have searched all over the internet and I can't solve it so I would appreciate it if you could help me. At least with some tips. Thank you.
You need to specify either the outlet temperature of the water or its mass flow rate.
As far as the F12 is concerned, the open system (control volume) version of the first law of thermodynamics applied to the F12 side of the heat exchanger gives us:
$$0=\dot{Q}+\dot{m}(h_{in}-h_{out})$$where ##\dot{Q}## is the rate of heat addition to the F12 (-58 kW), ##h_{in}## is the specific enthalpy of the F12 entering the heat exchanger, ##h_{out}## is the specific enthalpy of the F12 exiting the heat exchanger, and ##\dot{m}## is the mass flow rate of the F12. What do you get for the specific enthalpy change of the F12 in passing through the heat exchanger? What do you get for the mass flow rate?
How do I calculate ##h_{in}## and ##h_{out}##? I know that h=u+PV but I don't know the specific internal energy (u) or the volume.
I hope you didn't think you were going to be able to solve this without any physical property data on F12. Get yourself a set of thermodynamic tables for F12, either from a textbook or on the internet.
So I found this table. 7 bar equals 700 kPa, so this is the part of the table that would matter for that pressure. Would I have to replace the H in the equation you showed me to calculate the mass flow rate?
Sure. But before addressing that, please answer this question: Is the F12 under these conditions (a) a saturated vapor or (b) a superheated vapor?
I think its a superheated vapor.
There is definitely information missing from this problem. Are you sure you have provided the complete problem statement?
Yes I'm sure so. Although I have to do it using a program called Aspen, don't know if you are familiar with it, and maybe with the tips you gave me and using the program it can help finding the miss information.
Aspen can't help you with that unless there is additional information available involving conditions at the juncture with other equipment in the process. Where did the value you cited for the heat load come from? Certainly, if you are using Aspen, you must know the process flow rate.
It was from the problem, I didnt calculate it.
What is the exact word-for-word statement of the problem?
It's exactly what my first post on this thread says. Do you think that knowing the initial temperature and pressure of the water and that it was transferred 58w to it in a 10m2 area will give us the final temperature and pressure of water? It also asks to:
b) Characterize the flows that leave the permuted
c)Graph the freon-12 output temperature variation with the heat transfer area
d)show the models for the prediction of thermodynamic properties
There is still a lot of information desperately missing. Any information of the design details of the heat exchanger like number of tubes, diameter, metal, etc? I feel like you are holding back vital information. By this point in your training, you should know what info is necessary to design/analyze a heat exchanger.
No I don't have any of that information. What I've said until now it's all the information they gave me.
https://www.che.iitb.ac.in/faculty/madhu/CL152/Handouts/Handout%206.pdf
Do you think any of these formulas would help?
Well, you have closure on the F12 side of the exchanger if you assume that it leaves the exchanger as a saturated liquid at 7 bars. That gives you the exit temperature and the exit specific enthalpy. But, on the water side, you need to know the exit temperature of the mass flow rate to provide closure.
Definitely not my field, but it seems there is enough data for a solution; especially if it is looked at as a condenser for the F12.
Could this be an 'Ideal Situation' question by the OP. Since the F12 inlet and outlet pressure & temperature are known and the total energy transfer is given. They are asking for the F12 flow rate constrained by the coolant (water) temperture and pressure (15C to 100C, 1bar).
Cheers,
Tom
Cheers,
Tom
The outlet temperature and pressure (and mass fraction liquid) of the F12 are not specified in the problem statement. To get closure, at least on the F12, one would have to assume (without justification) that the outlet condition is a saturated liquid (or some other mass fraction liquid) at 7 bars (and about 26 C). Then, the mass flow rate of the F12 could be calculated.
There is no information on either the outlet temperature of the water or its mass flow rate. Certainly, the outlet temperature cannot be 100 C or the 2nd law of thermodynamics would be violated. The outlet temperature of the water cannot be higher than the inlet temperature of the F12.
1. What is a heat exchanger?
A heat exchanger is a device that is used to transfer thermal energy between two or more fluids, without allowing them to mix. It typically consists of a series of tubes or plates that allow the fluids to flow in close proximity to each other, facilitating the transfer of heat from one fluid to the other.
2. How do heat exchangers work?
Heat exchangers work by allowing two fluids at different temperatures to flow in close proximity to each other. The heat from the hotter fluid is transferred to the colder fluid, causing the hotter fluid to cool down and the colder fluid to heat up. This process continues until the two fluids reach a state of thermal equilibrium.
3. What are the different types of heat exchangers?
There are several types of heat exchangers, including shell and tube, plate and frame, and air-cooled. Shell and tube heat exchangers consist of a shell (outer vessel) and tubes (inner vessels) that allow the fluids to flow in opposite directions. Plate and frame heat exchangers use plates instead of tubes to facilitate heat transfer. Air-cooled heat exchangers use air as the cooling medium instead of a liquid.
4. How are heat exchangers used in industries?
Heat exchangers are used in a wide range of industries, including chemical, oil and gas, power generation, and food and beverage. They are commonly used for heating and cooling processes, such as in boilers, refrigeration systems, and heat recovery systems. They can also be used for heat transfer in chemical reactions and in the production of various products.
5. How do energy balances play a role in heat exchanger design?
Energy balances are crucial in heat exchanger design as they help determine the amount of heat that needs to be transferred between the two fluids. By calculating the energy balance, engineers can determine the appropriate size, materials, and flow rates for the heat exchanger to ensure efficient heat transfer. Energy balances also help in optimizing the design for maximum energy efficiency and cost-effectiveness.
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • General Engineering
  • Thermodynamics
