Calculating Heat Generated in a Coil due to Changing Current and Resistance
The discussion focuses on calculating the heat generated in a coil with resistance R due to a charge q passing through it while the current decreases uniformly to zero over a time interval Δt. The relevant equations include dH = i²Rdt and i = dq/dt. Participants explore the relationship between current, charge, and time, ultimately deriving the equation i = i₀ - at, where i₀ is the initial current and a is a constant related to the rate of decrease. The final expression for heat generated is H = (i₀²RΔt - aRΔt²/2).
  • Understanding of electrical concepts such as current, resistance, and charge.
  • Familiarity with calculus, particularly differential equations and integration.
  • Knowledge of the relationship between current and charge over time.
  • Ability to manipulate and solve equations involving multiple variables.
  • Study the derivation of the heat equation in electrical circuits, focusing on dH = i²Rdt.
  • Learn about the integration of piecewise linear functions to understand current decay.
  • Research the relationship between charge, current, and time in electrical systems.
  • Explore advanced topics in thermodynamics related to heat generation in resistive materials.
Students in physics or electrical engineering, educators teaching thermodynamics and circuit theory, and professionals analyzing heat generation in electrical components.
AdityaDev
What amount of heat will be generated in a coil of resistance R due to a charge q passing through it if the current in the coil decreases down to zero uniformly during a time interval ##\Delta t##
##dH=i^2Rdt##
##i=\frac{dq}{dt}##
##dH=i^2Rdt##
##dH={\frac{dq}{dt}}^2Rdt##
##dH=\frac{{dq}^2R}{dt}##
How do I solve this multi variable differential equation?
##dH=i^2Rdt##
##i=\frac{dq}{dt}##
##dH=i^2Rdt##
Your are told the current decreases uniformly with time. Write that as an equation.
##i=-at##
##di=-adt##
##dH=iR^2dt##
##dH=-aR^2tdt##
##H=-aR^2\frac{t^2}{2}##
I see an unknown a appearing, whereas the known (given) q has disappeared.
And the math leaves to be desired:
  • ##i = -at## can't be right (try ## t=0## and ## t = \Delta t##)
  • Any reason for ##i^2R## changing into ##iR^2## ?
With ##t## in the answer I suppose you mean ##\Delta t## ?
Any chance to present the answer in terms of the givens ?
Big typing mistake sorry
##di/dt = -a##
This shows that i decreases with time, just like dN/dt=-N for nuclear decay.
Hence you will again get I=-at.
##di/dt = -a##
You're forgetting the constant of integration. The current starts positive and finishes at zero. And you need to relate a to q.
And it is not like nuclear decay which follows a negative exponential with time, not linear.
##i = i_0 - at##
##dH= (i_0 - at)^2Rdt##
##H=i_0^2Rt - aRt^2/2##
Still this annoying a ...
And a strange result for the integral...
##i=i_0-bt##
Please help me solve this
You can't exclude a because the equation will become dimensionally incorrect
Now it fits for t=0. Next: make it fit for ## t = \Delta t##.
And (to keep in the back of your mind): ##q = \int_0^{\Delta t}\; i \;dt ## to eliminate ##I_0##
[edit] from zero to Delta t
##i=\frac{q}{\Delta t} - at##
No that doesn't seem right.
##i=i_0 - \frac{i_0t}{\Delta t}##
##i=i_0-at## not good ? try ##i=i_0-bt## or ##i=i_0-ct## :)
Reminded me of this joke where you see Einstein in front of a blackboard with ## E=ma^2 ## and ## E=mb^2 ## stricken through, and then ## E=mc^2 ## ! (with an exclamation mark). Sorry.
What I am pushing towards: ##i=i_0-at## is correct, but not good enough. t = 0 works fine, now fill in ##\Delta t## when you know ##i(\Delta t) = 0 ## you get a.
Bit now you have ##i_0## as unknown. However, ... (see post #11)
[edit] crossed post #14. Bingo !
Ok...here comes my updated equation
##i=\frac{q}{\Delta t} - \frac{q}{(\Delta t)^2}t##
Almost :)
Is it correct?
Now can I use i2Rt?
Almost means: not there yet: $$q \; {?\atop =}\ \int_0^{\Delta t}\; i \;dt = {q\over \Delta t} \int_0^{\Delta t} \;(1-{t\over \Delta t}) \; dt = {q} \int_0^{\Delta t} \;(1-{t\over \Delta t}) \; d({t\over \Delta t}) = q\int_0^1 (1-u) du = {q\over 2}$$so there is a 2 missing. Obvious if you sketch i(t), a triangle.
At t=0,you get ##q=i\Delta t##.
Here you get Q=q/2
What is the difference between the two 'q's?
(I got the answer after using post 19. Thank you very much)
No, at t=0 you get ##i = i_0 = {2q\Delta t}##
Q = q/2 ? There should come q = q !
And the picture refuses to be uploaded, sorry. Can't copy and paste a picture either. Must be some issue thanks to the security mafia.
1000 words:
a triangle from (0, ##I_0##) to (##\Delta t##, 0).
Area ##{1\over 2} I_0\Delta t \equiv q \Rightarrow I_0 = ...##
I don't know why you had this objection to introducing a. It should then have been a simple matter to find a in terms of q and ##\Delta t## by integrating.
Yes, we're working on that. Nearly done (see post #16). Or completely -- I don't know what I can deduce from post #20.
It was more the duo ##i_0## and a , of which I picked a to eliminate. But you are referring to post #8; we are at over 20 now ...
11K
