Heat released during combustion at constant pressure vs volume
The discussion clarifies the thermodynamic principles governing the heat released during combustion reactions at constant pressure versus constant volume, specifically using the combustion of heptane (C7H16). It establishes that the enthalpy change (dH) at constant pressure is equal to the heat released (q), while at constant volume, the heat released is adjusted by the change in the number of moles of gas (Δn). The conclusion is that combustion at constant pressure releases more energy than at constant volume due to the work done on the system by the surroundings, which is not accounted for in constant volume conditions.
  • Understanding of thermodynamic concepts such as enthalpy (dH) and internal energy (dU).
  • Familiarity with the ideal gas law and its implications in thermodynamic processes.
  • Knowledge of Hess's law and its application in relating different thermodynamic states.
  • Basic understanding of combustion reactions and their exothermic nature.
  • Study the principles of Hess's law in greater detail to understand energy relationships in thermodynamic processes.
  • Learn about the ideal gas law and its application in calculating changes in internal energy and enthalpy.
  • Explore the differences between exothermic and endothermic reactions in the context of thermodynamics.
  • Investigate the implications of constant pressure versus constant volume conditions in various chemical reactions.
This discussion is beneficial for students and professionals in chemistry and engineering, particularly those focusing on thermodynamics, combustion processes, and energy transfer in chemical reactions.
ChasingZebras
Greetings! I've been brushing up on some thermodynamics recently and came across a perplexing sentence in my notes and text from undergrad.
It says that for a combustion reaction, such as the combustion of heptane:
C7H16 (l) + 11O2 (g) ---> 7CO2 (g) + 8H2O (l)
That this process carried out at constant pressure would release more energy than the same process carried out at constant volume.
I realize that enthalpy change is: dH = dU + d(PV), and that under constant pressure dH = q, and under constant volume dH = q + V(dP)
dU = q - w
Where q is heat added into the system, and w is work done by the system
Since the combustion is exothermic, q is negative
The moles of gaseous products are less than the moles of gaseous reactants, thus under constant pressure conditions, the volume of the system has decreased, thus work is done ON the system by the surroundings, and w here is negative (making the term positive). Thus,
dU = -q - (-w)
dU = -q + w
And, dH = -q + w + V(dP) + P(dV)
dH = -q + P(dV) + V(0) + P(-dV)
dH = -q
Under constant volume conditions, once products are formed the pressure of the system has decreased (because less moles of gas), and NO work is done since volume is constant. Thus,
dU = -q - (0)
dU = -q
And, dH = -q + V(dP)
If the pressure of the system has decreased, then dP is negative
dH = -q - V(dP)
So we have at constant pressure: dHp = -q
and at constant volume: dHv = -q - V(dP)
Therefore, wouldn't the process carried out at constant volume release more energy than the same process carried out at constant pressure? Since dHv < dHp, thus more exothermic/more energy release?
Did I go wrong somewhere? Or are is there a possible error in my notes/text?
Any clarification is much appreciated. Thank you for your time!
Chemistry news on Phys.org
You are right that q is negative, but that doesn't mean dH = -q. dH = q, and dH is also negative.
You seem to be assuming that q is the same for both conditions. Why? What actually is the same?
We need to be careful, because we are dealing with two different sets of starting and end states here.
A. Combustion at constant pressure:
Initial state: Reactants at To, Po, Vo
Final State: Products at To, Po, and V1
B. Combustion at constant volume:
Final State: Products at To, P1, Vo
Note that, in situation B, the final state is different from the final state in situation A. This needs to be taken into account in relating the heats of combustion for the two changes.
Let's first consider situation A. For this situation, we have $$Q_A=\Delta H_A$$ and $$\Delta U_A=\Delta H_A-(P_0V_1-P_0V_0)=\Delta H_A-\Delta n RT_0=Q_A-\Delta n RT_0$$
Next, let's consider situation B. For this situation, we have $$Q_B=\Delta U_B$$
We next need to relate the internal energy changes in situations A and B. Since the initial states are the same in both situations, by Hess' law, we can write: $$\Delta U_B=\Delta U_A+\Delta U_{AB}$$where ##\Delta U_{AB}## is the change in internal energy from the final state of situation A to the final state of situation B. In the final states, the temperatures in the two situations are exactly the same and we are dealing in both cases solely with the products of the reaction. Since the internal energy of an ideal gas products mixture is a function only of temperature, we must have ##\Delta U_{AB}=0##. Therefore, it follows from the previous relationships that:
$$\Delta U_B=\Delta U_A$$and $$Q_B=Q_A-\Delta nRT_0$$Therefore, if the change in the number of moles of gas ##\Delta n## is negtive (as in your example), the amount of heat that would have to be removed when carrying out the reaction at constant volume would have to be less than the amount of heat that would have to be removed at constant pressure. This is consistent with what your notes say.
That doesn't make any sense when your talking about energy, higher pressure is just condensing the energy and the more volume the more you have to work with. Why do you figure these two different quanitys bear the same relationship?
Just because this doesn't make sense to you, doesn't mean that it doesn't make sense. (What you've written doesn't make sense to me. I've never heard of energy being condensed, for example) The analysis I presented is based on a routine straightforward thermodynamic treatment of the problem. If you are having trouble understanding one (or more) of the equations I've presented, maybe I can help. Have you had a course in thermodynamics yet?
No I haven't, my fault. I'm trying to express density of kenetic energy,
Thank you so much for this comprehensive reply - I see where my faulty thinking was. I incorrectly assumed the amount of heat (q) evolved would be the same under both conditions. It all makes sense now ;D
  • · Replies 31 ·
