Calculating Temp. in a Heated Vessel: A Problem for Dave
To calculate the temperature inside a heated cylindrical vessel using combustion heat, one must first determine the flame temperature generated by the combustion of natural gas. The energy content of the fuel (MJ/kg) and its flow rate (kg/s) are essential for estimating the heat transfer through the vessel's wall, which is influenced by the wall thickness, material, and volume. The process involves treating the situation as a heat transfer problem, where the flame temperature serves as the initial heat source.
  • Understanding of heat transfer principles
  • Knowledge of combustion processes and flame temperature calculations
  • Familiarity with material properties related to thermal conductivity
  • Basic skills in thermodynamics
  • Research methods for calculating flame temperature for natural gas combustion
  • Study heat transfer equations relevant to cylindrical vessels
  • Explore thermal conductivity of various materials used in vessel construction
  • Learn about energy balance calculations in thermodynamic systems
Engineers, thermodynamic analysts, and anyone involved in thermal management of combustion systems will benefit from this discussion.
davidgrant23
Hi there,
I have a problem that I cannot find a solution too. In this problem I have a fuel (approximately natural gas) supply which is combusted when mixed with air inside a burner. The flame that is then generated is used to heat up a sealed cylindrical vessel (the flame is on the outside of the vessel, but the combustion heat is used to heat up the inside of the vessel).
Now, I know the energy content of the fuel (MJ/kg) and the flowrate (kg/s). However, I am required to estimate the temperature inside the vessel during heating by the flame. The other information I know are the vessel wall thickness, wall material, and vessel volume.
How would I go about calculating the temperature inside the vessel? Do I need to calculate the flame temperature and then treat it as a simple heat transfer problem? Or can I simply use the energy content of the fuel and mass flowrate to calculate the energy on one side of the wall?
Cheers,
Dave
Science news on Phys.org
The gas in the container doesn't know that it is being heated by a flame on the outside of the container, right? So, you need to know the flame temperature. This is just the starting point.
  • · Replies 41 ·
