How Can I Calculate Hot Water Usage in My Home?
  • Context: Undergrad
  • Thread starter Thread starter MrDieselT
    Cooling Heating Water
This discussion focuses on calculating hot water usage in residential settings, specifically addressing the temperature and volume of hot and cold water used during showers. The user seeks to determine the amount of 140°F hot water and 50°F cold water utilized when taking a 20-gallon shower at 105°F. Additionally, the discussion explores how to calculate the resulting temperature in an 80-gallon tank after replacing the used hot water with cold water. The user aims to develop a program to estimate hot water consumption based on household variables.
  • Understanding of thermodynamics principles related to heat transfer
  • Familiarity with the concept of BTUs (British Thermal Units)
  • Basic knowledge of water temperature and volume calculations
  • Experience with programming for developing calculation tools
  • Research the formula for mixing water at different temperatures
  • Learn about BTU calculations for heating water
  • Explore programming languages suitable for developing calculation applications
  • Investigate existing software solutions for tracking household water usage
Homeowners, plumbing professionals, engineers, and developers interested in optimizing hot water usage and efficiency in residential settings.
MrDieselT
Ok so my question is about hot water in a home
Lets say that I take a shower a shower and i use 20 gallons of water at 105* F
If the hot water in my tank is at 140*F
and my cold water comes in at 50*F
how much of hot (140*F) water did i use?
How much cold (50*F) Water did i use?
Now this might be on the same formula but
lets take the volume of 140*F hot water that I used in my shower out of the hot water tank and replace it with the same volume of 50*F Cold water to refill the tank, what will the temperature in the tank be now if its a 80 Gal Tank? (don't worry about the burner bring it up to temp)
Science news on Phys.org
This is a HW type problems and so will be moved from here.
I thought it was a thermo problem. Its not a HW type problem if that what your thinking, I own a company that sells solar products (PV & Thermal) and of all the pros and books out there i can't find much on this topic.
I wanted to develop a program that would be able to calculate how much hot water a house uses based on the number of showers, people and other items in a house that use hot water. by finding what the temperature in the tank falls to I can then calculate the BTU's and thus collectors needed to bring the thank back up to temperature.
  • · Replies 66 ·
  • · Replies 32 ·
9K
