How Much Does Adding Ice Cool Your Coffee?
  • Thread starter Thread starter Awer1
    Transformation
The discussion centers on the calculation of the final temperature of coffee after adding an ice cube. An insulated Thermos contains 120 cm³ of coffee at 80.0°C, and a 19.0 g ice cube at its melting point is introduced. The correct formula for calculating the final temperature (Tf) is Tf = \frac{[(Ti)(Cw)(Mw) - (Hfus)(Mi)]}{Cw(Mw+Mi)}, leading to a final temperature of approximately 21.81°C. The discrepancy arises from unit conversions, particularly the treatment of the latent heat of fusion, which should be expressed as 333,000 J/kg for consistency in calculations.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with specific heat capacity and latent heat concepts.
  • Proficiency in unit conversions, particularly between Joules and kilojoules.
  • Basic algebra skills for manipulating equations.
  • Study the principles of heat transfer in thermodynamics.
  • Learn about specific heat and latent heat calculations in detail.
  • Practice unit conversions between different measurement systems.
  • Explore real-world applications of thermodynamic principles in cooking and beverage preparation.
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in the science of temperature changes in liquids.
Awer1
1. An insulated Thermos contains 120 cm3 of hot coffee at 80.0°C. You put in a 19.0 g ice cube at its melting point to cool the coffee. By how many degrees (in Celsius) has your coffee cooled once the ice has melted and equilibrium is reached? Treat the coffee as though it were pure water and neglect energy exchanges with the environment. The specific heat of water is 4186 J/kg·K. The latent heat of fusion is 333 kJ/kg. The density of water is 1.00 g/cm3.
2. Tf = \frac{[(Ti)(Cw)(Mw) - (Hfus)(Mi)]}{Cw(Mw+Mi)}
3. Tf = (120cm3)(1.00x10-3\frac{kg}{cm^3})(4186x10-3\frac{kJ}{kg K})(80+273)K - (333\frac{kJ}{kg}x(19x10-3kg))/(4186x10-3\frac{kJ}{kg K})(19x10-3kg)+(120x10-3kg)
= 293.8743396K - 273K = 20.87433961oC
The answer the book has.. : 21.809113626442oC
After reworking the algebra the only way the book could of gotten that answer is if they didn't substitute any of the units and only changed the value 333 \frac{kJ}{kg} to a value of 333000. which gives an answer of 58.19088637oC. which they then subtract it from the initial temp to get ..--> 80 - 58.19088637 = 21.80911363oC. How is that even right? You have to convert everything so that the units match up right?.. in the books case how are the units being canceled out?
Here is my question: Who is right?
The book is right. If you're adding 273 to all your temperatures to work in Kelvins, I don't see where you added 273 to the temperature of the ice. (Alternatively, you could just work in degrees Celsius.)
  • · Replies 17 ·
