Undergrad Heisenberg uncertainty principle and the canonical momentum operator
The Heisenberg uncertainty principle establishes limits on the simultaneous measurement of position and momentum due to the non-commutative nature of their respective operators. The momentum operator, defined as ##\hat{p} = -i\hbar \frac{\partial}{\partial x}##, is applicable in free space but requires modification in the presence of a vector potential, leading to the canonical momentum expression ##\mathbf{p} = m \mathbf{v} + q\mathbf{A}##. This distinction is crucial for charged particles, as the canonical momentum differs from the mechanical momentum when electromagnetic fields are involved. The discussion also touches on the Poisson bracket formalism and the Stone-von Neumann theorem, emphasizing the relationship between classical and quantum mechanics. Understanding these concepts is essential for accurate applications of quantum mechanics in various physical contexts.
wnvl2
Heisenberg uncertainty principle relates to the limitations on the precision with which certain pairs of physical properties (like position and momentum) of a particle can be simultaneously known. The uncertainty relations for position and momentum as operators arise from the non-commutative nature of these operators. Specifically, the position ##\hat{x}## and momentum ##\hat{p}## operators do not commute, which leads to a fundamental limit on the precision with which these quantities can be simultaneously measured.
Can these relations in al situations be applied for the momentum operator
\hat{p} = -i\hbar \frac{\partial}{\partial x},
or should in some cases the canonical momentum operator be used?
For instance if I want to apply the Heisenberg uncertainty relations to the kernal of an atom is it simply with operator
or do I have to us a more complex operator for the canonical momentum?
Not only free space but also in general field, that formula is applicable.
For motions of charged particles momentum is transformed as
p\rightarrow p-eA
but it does not affect that formula, I think. Corrections by experts are welcome.
Do you know Poisson's brackets? This can be used to make canonical quantization clear.
Edit: also there is a generalized uncertainty principle that you should check.
I know Poisson brackets. I will check the generalized uncertainty principle.
So basically if the Poisson brackets between your canonical variables are ##\{q,p\}=1## then you quantize by fixing that the operators must not commutate and be given by ##[\hat{q},\hat{p}]=i\hbar##. So yeah, it is the canonical momentum in the position base that is written as ##-i\hbar \partial/\partial q## in the position (whatever ##q## and ##p## are). The same happens with angle ##\theta## and angular momentum around that angle, where ##L_z=-i\hbar\partial/\partial\theta##.
Check Conjugate variables (Wikipedia)
For a less trivial example you can check the quantum LC circuit (that is sometimes used to model superconductive circuits). In that you quantize the charge in the capacitor and its conjugate momentum (voltage).
Only for a free particle. For a particle in a vector potential ##A##, the canonical momentum has an extra term ##e A##, where ##e## is the charge. That means the operator ##- i \hbar \partial / \partial q## and the canonical momentum operator are no longer the same. And if ##A## does not commute with the position operator, there will be different Heisenberg uncertainty relations with position for the two operators.
  • Skeptical
Likes pines-demon
Isn't it the whole point of minimal coupling saying that in the presence of ##\mathbf A(\mathbf r)## that the canonical momentum is ##\mathbf p = m \mathbf v + q\mathbf A (\mathbf r)##? So you have to replace ##\mathbf p_{\text{free}} \to \mathbf p - q\mathbf A(\mathbf x)## [compare signs] and is the new ##\mathbf p## that is written as ##-i\hbar \nabla## (and not the one representing old momentum ##\mathbf p_{\text{free}}=m\mathbf v##)?
Correct. You still have ##\mathbf{p} = -i\hbar \nabla##, but ##\mathbf{p}## is no longer ##m \mathbf{v}##.
Likes pines-demon
And do you agree that the ##\mathbf p=-i\hbar\nabla## that you defined IS the canonical momentum? (even if ##\mathbf p\neq m\mathbf v##).
Yes. To quote from Sakura and Napolitano, Modern Quantum Mechanics:
Quite often ##\mathbf{p}## is called canonical momentum, as distinguished from kinematical (or mechanical) momentum, denoted by ##\mathbf{\Pi}##:
\mathbf{\Pi} \equiv m \frac{d \mathbf{x}}{dt} = \mathbf{p} - \frac{e \mathbf{A}}{c}.
Likes wnvl2, anuttarasammyak and pines-demon
Is that the case? The canonical definition is derived from the Lagrangian: ##p = \delta L / \delta \dot{q}##. That doesn't seem like the same thing.
The Lagrangian is
$$L=\frac12 m\dot{\mathbf q}^2+Q\dot{\mathbf q} \cdot \mathbf A$$
$$p_i=\frac{\partial L}{\partial \dot{q}_i}= m \dot{q}_i+Q A_i $$
Writing the Hamiltonian
$$H=\sum_i p_i \dot{q}_i-L=\frac{m \dot{q}^2 }{2}=\frac{|\mathbf p - Q \mathbf A|^2}{2m}$$,
and that ##\mathbf p## is the one that becomes ##-i\hbar \nabla##.
How does that happen? That's my question. You can't just declare by fiat that they're the same.
Because that's how canonical quantization works. We are working in the Hamiltonian picture with position and canonical momentum. Have you ever solved a particle in a magnetic field (Landau levels) we certainly do NOT make ##\mathbf p - Q \mathbf A=-i\hbar \nabla##.
pines-demon said:
a particle in a magnetic field (Landau levels) we certainly do not make ##\mathbf p - Q \mathbf A=-i\hbar \nabla##.
Ah, ok, I was misunderstanding what you said.
I still do not know what you meant in #8.
The Lagrangian for a particle in a vector potential includes a term ##e v \cdot A##, which leads to a term ##e A## in the canonical momentum: it becomes ##p = M \dot{q} + e A##. (See, for example, Ballentine, section 11.1. I used ##e## for the charge instead of ##q## to avoid confusion with the configuration variable ##q##.)
The thing that might need to be spelled out more explicitly is how we get from ##p = M \dot{q} + e A## to ##p = - i \hbar \partial / \partial q##. I posted post #8, and subsequent posts, to raise that question.
pines-demon said:
Using the canonical quantization you get that ##\{x,p\}=1\to[\hat x, \hat p ]=i\hbar##.
Ah, I see; it relies on the Poisson bracket--commutator correspondence. Ballentine, Section 3.6, discusses limitations of that approach to quantization, which is not the approach Ballentine takes. Ballentine's (very brief) discussion of canonical momentum makes no mention of canonical quantization, nor does it appear to me to make use of ##p = - i \hbar \nabla##. I'm not sure how the latter formula would be derived in the general case using Ballentine's approach.
pines-demon said:
the rigorous name is Stone-von Neumann theorem.
That's the theorem that shows that all representations of the canonical commutation relations must be unitarily equivalent. (Note that the theorem only holds for the case of finitely many degrees of freedom; for the case of infinitely many degrees of freedom, as in quantum field theory, there are unitarily inequivalent representations, which is a major issue in QFT foundations.)
Likes pines-demon
Ballentine cites J.R. Sewell 1959 for the canonical commutation, it has a good discussion on that and its many limitations, the uniqueness of the mapping of the commutator to ##-i\hbar \partial_q## fails when not all conditions are met. Sewell contents himself with saying that it works for simplicity which is a principle often used in physics. However I also wonder what are the modern alternatives if any...
Could you please give the full citation of that article?
Thanks for the good information. May we regard that (which ?) one of ##\Pi, p## is mechanical momentum of a charged particle and the other is mechanical mometum of the system,i.e. a charged particle and EM field ?
What is mechanical momentum?
I find it in the DrClaude's quote of Sakurai. I would like to understand more clearly how we should deal with momentum of canonical/kinetatical(mechanical) for a particle/em field/both(the system), and which corresponds to x-differential operator of particle.
pines-demon said:
Thanks!
They both concern only the particle. The vector potential ##\mathbf{A}## and scalar potential ##\phi## correspond to an external electromagnetic field (they do not take into account the field created by the charged particle).
Likes pines-demon
Thanks. Landau, classical thery of field says
sign of A is different from Sakurai and Napolitano. It is due to conventions they refer or I take wrong correspondence of P,p in Landuau and ##\Pi##, p in Sakurai ?
Again the canonical momentum is ##\mathbf P=m\mathbf v +q\mathbf A=\boldsymbol \Pi+q\mathbf A##, where ##\boldsymbol \Pi## is the ordinary momentum. All the books are consistent unless the charge is taken as negative for electrons.
Likes div_grad, anuttarasammyak and DrClaude
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 56 ·
  • · Replies 16 ·
