HELP A problem on determine electric field in vector form
The discussion focuses on calculating the electric field vector from a given electric potential function, V(x,y). The initial confusion arises from incorrectly evaluating the potential at a specific point instead of deriving the electric field. Participants emphasize the need to apply the relationship between electric field and potential, specifically using the negative gradient of the potential. The correct approach involves taking partial derivatives with respect to x and y while treating the other variable as constant. Clarifications on the proper application of calculus and the chain rule are provided to guide the solution.
Kudo Shinichi
HELP!A problem on determine electric field in vector form
The electric potential due to a charge distribution is given by V(x,y)=((100x)/(x2+y2)3/2)*Volts
where the distances are in meters. What is the electric field (vector) at the position x=2m, y=0.2m?
V(x,y)=((100*2i)/(22i+0.22j)3/2)*volts
V(x,y)=(200i/(8i+0.008j))*volts
This is how I tried to solve the problem but I don't think that I did it correctly because I don't think that I can write a function with two directions together.
Can anyone help me with it? thank you very much
One thing is clear: You aren't reading your textbook.
First, they ask for the electric field, not the electric potential. So you are not supposed to evaluate V(x,y) at the given point. And even if you were supposed to do that, it makes no sense to insert the unit vectors \hat{i} and \hat{j} in there (where would those come from anyway??).
Please look in your book and find the definition of electric field in terms of electric potential. Then we can get started.
Sorry about that I didn't read the problem properly...
dV=-E*dl
E=-dV/dl
Then separate the x and y direction
Ex=-\deltaV/\deltax
Ex=-(100/(3/2(x2+y2)1/2*(2x+y2))
Ey=-\deltaV/\deltay
Ey=(100x/(3/2(x2+y2)1/2*(x2+2y))
then sub in x and y
is it right?
Your derivatives are wrong. If you post the steps you took to calculate them then I can show you where you made a mistake.
Ex=-\deltaV/\deltax
For this only we only have to derive x and let y be constant
the original equation is 100x/(x2+y2)3/2
since we only need to derive x
then the equation becomes
100x-->100
use chain rule to do the following=outside derivative times inside derivative
(x2+y2)3/2
3/2(x2+y2)1/2*(2x)
Ex=-(100/(3/2(x2+y2)1/2*(2x))
same for y but for this only derive y and let x be constant
Ey=-\deltaV/\deltay
Ey=(100x/(3/2(x2+y2)1/2*(2y))
(a) The polarisation pattern is elliptical with maximum (1,1) and minimum (-1,-1), and anticlockwise in direction. (b) I know the solution is a quarter-wave plate oriented π/4, and half-wave plate at π/16, but don't understand how to reach there. I've obtained the polarisation vector (cos π/8, isin π/8) so far. I can't find much online guidance or textbook material working through this topic, so I'd appreciate any help I can get. Also, if anyone could let me know where I can get more...
  • · Replies 17 ·
  • · Replies 0 ·
