Help Again Please - Box sliding on a floor
  • Thread starter Thread starter jbow615
    Box Sliding
The discussion centers on calculating the change in kinetic energy of a box sliding on a floor with a friction coefficient of 0.23 and a mass of 12 kg. The total work done is derived from the applied forces and the friction force, resulting in a change in kinetic energy of -82.48 J after traveling 4 meters. The calculations involve determining the friction force using the equation F_friction = μ * N, where N is the normal force, and applying the work-energy principle. The confusion arises from conflating two separate questions regarding the box's motion on a frictionless surface.
  • Understanding of Newton's laws of motion
  • Knowledge of kinetic energy and work-energy principle
  • Familiarity with friction calculations, specifically F_friction = μ * N
  • Ability to resolve forces into components and calculate work done
  • Study the work-energy theorem in detail
  • Learn about friction coefficients and their impact on motion
  • Explore vector resolution of forces in physics problems
  • Investigate the effects of different surface types on kinetic energy
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of kinetic energy calculations involving friction.
jbow615
Help Again Please -- Box sliding on a floor
If the friction coefficient between the box and the floor is .23, and the box has a mass of 12 kg, and the magnitude of all four forces is 10 N, what is the change in kinetic energy of the box after it has traveled a distance of 4 meters to the east?
Friction force =(mu)(normal force)
w total= Kinetic final - Kinetic Initial
W total= force * distance
kinetic energy is 1/2mv^2
The attempt was calculating the friction force, calculating the applied force, and then subtracting the friction force from the applied force.
Show your work.
Friction force=(mu)(n). N=mg=(12)(9.8)=(117.6)(.23)=27.048
Work done by friction=(27.048)(4)=108.942
And I forgot this part of the question:
4 forces act on a crate on a friction less surface. Force 1 acts due east at 10 N, force 2 at at angle 50 degrees above the horizontal towards the east, force 3 due south, and force 4 due west. What is the work done by each force in increasing order?
So work done by applied force = 10cos(50)*4=25.711
So change in Kinetic Energy= Work of applied force - work of friction force which equals 25.711-108.942=-82.48
You seem to have conflated two questions. In the OP there is friction, in your second post there is none. The OP asked for change in KE of the box, while the second post asks for the work done by each force.
I don't understand your attempt at an answer. Where does the 4 come from? You would need to be multiplying a force by a distance; what distance?
  • · Replies 37 ·
