Help finding some specific elements for infrared (IR) sensor
1 reply · 1K views
Su-Te Tsai
Dear Everyone,
I'm searching for some specific elements for infrared (IR) sensor, such as Thermopile, Pyroelectric, Bolometer, MCT(HgCdTe), PbSe, or InSb sensors.
Does anyone know how to get these kinds of elements ?
( I need some information about the manufacturers...)
The elements are required to match the specifications(a. to e.) as follows:
1. Thermopile array #1:
a. Pixel pitch: 0.6 mm
b. Array type: 2 x 4 or 4 x 4
c. Sensing wavelength: 8 ~ 14 um
d. Output type: analog for every element
e. Element parameter:
i. Element size: 0.5 mm x 0.5 mm
ii. Sensitivity: 60V/W for 8~14u
iii. Resistance: 80kΩ
iv. Noise: 36 nV/√Hz
v. D*: 0.9 x 108 for 1Hz
vi. Time constant: < 6ms
2. Thermopile array #2:
a. Pixel pitch: 1.1 mm
b. Array type: 2 x 2
i. Element size: 1 mm x 1 mm
ii. Sensitivity: 50V/W for 8~14um
v. D*: 1.3 x 108 for 1Hz
vi. Time constant: < 10ms
3. Pyroelectric array:
d. Amplifier: with integrated voltage mode amplifier (ex. FET), every element
e. Operate frequency: 1Hz ~ 5kHz
f. Output type: analog for every element
g. Element parameter:
ii. Sensitivity: 120V/W for 1kHz and 8~14um
iii. Output impedance: ~100kΩ
iv. NEP: 3.8 x 10-10W/√Hz
v. D*: 2.5 x 108 for 1kHz
vi. Time constant: < 25ms
4. Bolometer array:
a. Pixel pitch: 0.3 mm
b. Array type: 8 x 8
d. Operate frequency: 1Hz ~ 5kHz
e. Output type: analog for every element
f. Element parameter:
i. Element size: 0.25 mm x 0.25 mm
ii. Sensitivity(before readout gain, 2V, 0Hz): 100,000V/W
iii. NETD(f/1, 300K, 30Hz): < 10mK
iv. D*: 8 x 108
v. Time constant: < 15ms
5. MCT(HgCdTe) or PbSe or InSb:
a. Sensor type: one element
b. Sensing wavelength: 3 ~ 5 um(cut-off λ= 4.9 ~ 6 um)
c. Element parameter:
i. Element size: 0.5 mm x 0.5 mm or 1 mm x 1 mm
ii. D*: 8 x 108
iii. Cooling: None or Built-in TEC type (Up to two TEC)
Thank you so much !Su-Te, Tasi.
Have you tried this?
It is so annoying to read FAQs. :oops:
